Need Help Bad` - BMW Forum - BimmerWerkz.com
Old 03-19-2005, 09:31 PM   #1 (permalink)
BimmerKris's Avatar
BimmerKris is an unknown quantity at this point
well, over the past couple weeks, my car has been on and off spuddering and been sluggish at times up to about 3000 RPM's then lights up and runs fine. At first it was occational, and would go away, after driving it. then it progressively got worse. Last night it was doing it pretty bad, then just stopped. It was idling like shit, and when i pushed on the gas pedal, it would almost stall right out and get worse. then it finally stalled. and now i cant get it to start at all. Ive done the o2 sensor and checked both fuel pumps and they are working fine. what else might cause this.
<img src='http://bmwforums.penguinstudios.com/BimmerKris/salesig%20copy.jpg' border='0' alt='user posted image' />
<a href='http://www.acantha.ca' target='_blank'>www.acantha.ca</a> 100% thrash your face off metal
BimmerKris is offline   Reply With Quote
Old 03-19-2005, 09:45 PM   #2 (permalink)
Kowalski's Avatar
[snapback]314941[/snapback]
fuel filter? air filter? vacume leaks most likley these are your problems. check for vacume leaks, cracked hoses, usualy the air boot is a culprit. if your not sure somthing is sealing put a hose clamp on it, i have hose clamps on all my vacume hoses.
264* roatation and 388 lift
Old 03-19-2005, 09:55 PM   #3 (permalink)
BimmerKris's Avatar
na, the fuel filter is new, air filters are always new, all the lines checked out, i'll try changing out AFMS and see it that changes things though
Old 03-19-2005, 10:03 PM   #4 (permalink)
Bmw1990's Avatar
Bmw1990 can only hope to improve
Send a message via AIM to Bmw1990
have u checked the intake boot?? If it has a crack in it, when you go to accelerate the engine is tweaked and that could open the crack and cut the engine out. could be a number of things
<img src='http://img127.imageshack.us/img127/4284/bmwlogo2new17jy.jpg' border='0' alt='user posted image' />
Black 4 door 1990 325i
15&quot;x7.5 Ronal LS-wrapped in 205/50-15 Bridgestone Potenza G009
Bmw1990 is offline   Reply With Quote
Old 03-19-2005, 10:28 PM   #5 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
What is the weather like around your area?
my dads car was getting condensation in the gas tank because of the weather and was just outright stalling while going 80 mph down the highway. When it was idling it would bounce around until it just died, his would start up after a couple of tries, but if there was enough water in your tank it wouldnt start at all i suppose. It would also be very sluggish until the rpm's got going.
catalyst. is offline   Reply With Quote
Old 03-20-2005, 09:53 AM   #6 (permalink)
Bmw1990's Avatar
If there is water just add some HEET to the tank and that will take care of it. There are many possibilities, i guess you just have to take one step at a time.
Old 03-20-2005, 10:18 PM   #7 (permalink)
BimmerKris's Avatar
changed out AFM's but did not help any other ideas
