| my shaking problem: Lower control arm Here is the story:
Since I got my car, its had a slight shaking problem. I knew it was either the bushings on the front right sway bar or the lower control arm. I took a look, and removed the wheel, and i am 100% sure its the ball joint on the lower control arm.
Problem: How do i remove the control arm? I did everything correctly and checked with the bently manual but i cannot remove the one bolt in the middle(the on which has a nut right next to the exhaust manifold)
How do I get this bolt off!?!?!?
__________________ "Bmw is better than Volvo, Robert" Retired ride: 1990 325i - Manual - Chipped - Recaro Racing Seats - Eibach Lowering Springs - Original German Liscense plate (for style) - Black HID Halo Angel Eyes - Blacked out Turn signals - alpina rims. :-) |
