Is my E30 terminal? - BMW Forum - BimmerWerkz.com
Old 05-04-2008, 07:40 AM   #1 (permalink)
bagelboy91's Avatar
Car: 91 318is
bagelboy91 is on a distinguished road
Is my E30 terminal?
1991 318is w/177k miles....
Driving last night on the highway when something let loose under the hood. I thought is was a tire blowout so i pulled over. Sounded like a very loud whooshing sound....imagine a tire letting go.
Thats not the case....its coming from under the hood, sounds like under the valve cover area or towards the front. She runs, but if i get over 1500 rpms, its sounds like marbles in a tin can....and very loud!
I limped it home shifting at 1500-2000 rpms, and it still had good compression. If i went over 2000rpms....it got crazy loud under the hood.
any ideas?
BagelBoy91
1991 318is
bagelboy91 is offline   Reply With Quote
Old 05-04-2008, 05:43 PM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
? does it idle ok? hmmm how was the temp?
1992 318i Coupe parts car
I am Captain Obvious
Old 05-09-2008, 11:28 AM   #3 (permalink)
bagelboy91's Avatar
Car: 91 318is
Idle is a bit rough...not crazy.
Temp was normal.
BagelBoy91
1991 318is
Old 05-09-2008, 12:25 PM   #4 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
you broke somethin....not really sure...hows the visual inspection check out when its running? anything off? wheres the sound coming from?
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 05-09-2008, 01:26 PM   #5 (permalink)
Maybe the timing chain is getting too loose?
Old 05-09-2008, 04:34 PM   #6 (permalink)
gotKRAUT's Avatar
being an M42 thats a good call...could be the timing tensioner
Kyle Sutherland
1995 BMW 540i/6:
Old 05-21-2008, 02:33 PM   #7 (permalink)
bagelboy91's Avatar
Car: 91 318is
I had a local mech look into this for me.....he thinks its a wrist pin on one of the cylinders.
BagelBoy91
1991 318is
Old 05-21-2008, 02:46 PM   #8 (permalink)
... that would mean it needs a rebuild...
Old 05-21-2008, 08:08 PM   #9 (permalink)
DIRTE30's Avatar
DIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond repute
Send a message via Yahoo to DIRTE30
You said it sounded like a whooshing sound? That definitely doesn't sound like a wrist pin? I would remove the valve cover and look down the timing chain to see if the tensioner or one of the guides let go... That could also explain the rough idle... could let the timing get advanced or retarded a little. Check it out first man!
DIRTE30 is offline   Reply With Quote
Old 05-26-2008, 11:33 PM   #10 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
WHOOSHING SOUND... that is the sound of a broken intake/air cleaner boot. engines suck air from the intake. that explains too the rough idle... when the measurement of the airflow(from the AFM) is not consistent with the airmass going into your intake chamber because of the break in ur intake.
sounds.... try and listen closely. upper engine rattling sounds that rise and fall with acceleration=valves(mal adjusted or at worst bent or broken); lower engine sounds lower in pitch the "clack-clack-clack" type of sound = con rods or wristpins or crank probs. contrast that to a "plack-plack-plack" = timing belt probs. ;-)
Change your oil and pay attention to metal bits if any... if none, then it isn't so bad ;-)
E30 M3 body panels on normal E30? shopkeep 3-Series (E21, E30) 5 05-30-2007 05:33 AM
WTT: 4dr e30 for 2dr e30 (socal) namelesspenguin Cars For Sale 0 12-08-2006 03:00 PM
Oooh Is It Terminal? bagpussxyz 3-Series (E36) 0 04-29-2005 04:59 PM
E30 Engine Swap,e28 M5 In E30 E30///M5 3-Series (E21, E30) 2 01-07-2005 02:24 AM
Fuse Blade Terminal Clips szidikj 3-Series (E21, E30) 0 08-16-2004 10:59 AM
