my car is not as responsive in 3rd gear as i would like? - BMW Forum - BimmerWerkz.com
Old 11-01-2005, 02:26 AM   #1 (permalink)
träumer is an unknown quantity at this point
what can i do to make that better. i floor it in third and it takes a secondor two to respond, like turbo lag?. i would like it to respond like it does in second gear. a lot quicker.
could it be my throttle adjustment?i have to adjust full throttle stop under gas pedal and throttle butterfly
bad wires,dist. cap , dist rotor?
bad fuel pressure regulator?
valves out of tuning? then why does it respond in second
could i have a burnt valve?
or could i have a computer problem? replace ecu
is my car just made like this?slow?
maybe i need to adjust air flow? check maf
bad injectors?
is the problem fuel delivery,air delivery or just some electronic fault or mechanical adjustment or fault.
if i buy a jc chip will it help?
thanks
träumer is offline   Reply With Quote
Car lurches intermittently when A/T shifts wango 3-Series (E36) 2 10-31-2005 03:28 PM
SMG questions... chuckie789 3-Series (E46, E90) 7 08-06-2004 10:55 AM
