My 325es Won't Run - BMW Forum - BimmerWerkz.com
Old 09-29-2004, 11:32 AM   #1 (permalink)
miliventi is an unknown quantity at this point
Thumbs up
My car starts OK. It will run for approximately 25 minutes or until the engine gets hot and then the enginee dies. After that I can not re-start it. I have to wait several hours before trying to re-start it again. Help.
miliventi is offline   Reply With Quote
Old 09-29-2004, 12:22 PM   #2 (permalink)
enimik's Avatar
enimik is an unknown quantity at this point
Does the temp raise quickly?
Im as lost as a gopher in a rabbits hole...?
enimik is offline   Reply With Quote
Old 09-29-2004, 02:05 PM   #3 (permalink)
[snapback]201372[/snapback]
The temperature rises normally.
Old 09-29-2004, 02:18 PM   #4 (permalink)
enimik's Avatar
ok, Check your fuel lines and filters, and injecters, also you might want to have your fuel pump looked at, more than likley its you feul pump. your engine is dying most likley to the lack of fuel, i had a car to were you could drive it like normal untill the fuel pump would just die out!
Old 09-29-2004, 02:31 PM   #5 (permalink)
I did check the fuel lines and replaced fuel filter with the same result. I believe that you hve a point that it is a fuel pump. Thank you for the reply.
My car 1986 vintage and has two fuel pumps. How do I go about troubleshooting which of the two is bad?
Old 09-29-2004, 02:34 PM   #6 (permalink)
enimik's Avatar
Have you checked the fuses to the feul pumps, and tighting the wires(power & ground) that go into the pumps!
It could also be electrical?
Old 09-29-2004, 02:45 PM   #7 (permalink)
Fuses and pump relay are OK. I also checked the wiring and it looks OK.
2001 325ci Won't Crank, Won't Start, Battery Good laurie325ci 3-Series (E46, E90) 4 06-14-2005 01:05 AM
318is Won't Start mojogator 3-Series (E36) 5 12-07-2004 01:16 AM
My Car Won't Start wilks88 3-Series (E36) 4 11-20-2004 10:01 AM
325I won't start in heavy SUNLIGHT 325iconverted 3-Series (E21, E30) 3 07-09-2004 12:15 AM
Driver Side Window Won't Seal bren 3-Series (E36) 3 07-07-2004 11:13 AM
