More ICV questions... - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 02-02-2007, 12:55 AM Thread Starter
Hey just a quick question on an old '90 325i I'm working on. The problem is a high idle. Does anyone know off hand if the (three wire) ICV is suppose to close if it is unplugged with the engine running? It would make sense that it does but this one doesn't and the idle is racing above 1,000 rpm, 2,000 with the A/C button depressed. I assumed the ICV piston was spring loaded to return to the closed position when power (plug) was removed. I pulled the plug off but had to tap it with a screwdriver handle to get it to close and drop the idle back to the baseline setting. Or I guess if anyone else has run across this and has the fix that would help too. I removed the ICV and sprayed it out with Amsoil PowerFoam, so it's shiny clean inside and moves freely. But I thought maybe there was a spring broke inside or something. Anybody got a three wire ICV they can go unplug and tell me what happens? I left it unplugged for now. Idles a smooth 700 rpms.
Thanks.
-Mike
Hamfisted is offline
post #2 of 3 (permalink) Old 02-02-2007, 08:26 PM
Starmavin is a jewel in the rough Starmavin is a jewel in the rough Starmavin is a jewel in the rough Starmavin is a jewel in the rough
Check your throttle position switch first, but there is a good chance your ICV is bad.
Starmavin is offline
post #3 of 3 (permalink) Old 02-02-2007, 09:13 PM Thread Starter
You called it right!
You called it right! This morning I went out and ran the tests on the TPS and it was dead. Both idle and WOT positions were dead. New TPS installed ($65) and all is well again. It may have been going bad for several months now and finally just died. Thanks for your response.
-Mike
Gear in this thread - Powered by O'Reilly Auto Parts
DIY - ICV (Idle Control Valve) Cleaning uber e36 3-Series (E36) 13 12-14-2015 01:23 PM
Diy Icv - 97 M3 paco1076 3-Series (E36) 0 10-19-2006 11:54 AM
3 Questions....plz help onlinegamesnz 5-Series (E12,E28, E34, E39, E60) 2 07-18-2006 01:57 AM
can someone show me where my ICV would be? Ivan 3-Series (E36) 16 05-27-2006 12:53 PM
Buying First Used Bmw, Have Some Questions ynotony 3-Series (E36) 1 06-06-2005 04:17 AM
