More Horse Power - BMW Forum - BimmerWerkz.com
Old 01-01-2005, 09:30 PM   #1 (permalink)
sexydylan05's Avatar
sexydylan05 is an unknown quantity at this point
Send a message via AIM to sexydylan05
i really wnat to add more power to my car i have an 86 325es its quick but i wnat more horses and torqe, so if anyone has any suggestens, like some cheep ways or i dunno anything would help. thanks guys
dylan
sexydylan05 is offline   Reply With Quote
Old 01-01-2005, 10:31 PM   #2 (permalink)
e36_m3_Turbo's Avatar
chip. exhaust.intake
No longer red.
Old 01-01-2005, 10:36 PM   #3 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
I suggest just adding a chip. Pouring money into a eta motor is pointless, save for that s50 swap
catalyst. is offline   Reply With Quote
Old 01-01-2005, 11:23 PM   #4 (permalink)
Aether's Avatar
Car: 1992 Jetta GLI
Aether is an unknown quantity at this point
Send a message via AIM to Aether Send a message via MSN to Aether
A Conforti chip and 225s will wake that car up.
Four Five Six - It's on.
Aether is offline   Reply With Quote
Old 01-02-2005, 05:41 PM   #5 (permalink)
The biggest change for the dollar is a differential ratio change.
My Webpage
Let's start with the road test. In acceleration, the 325is is only SLIGHTLY slower than the M3. (Zero to 60 in 7.5 seconds compared to 7.1 for the M3. Quarter mile in 15.7 seconds at 88.5 MPH compared to 15.4 seconds at 91 MPH for the M3). AND THIS IS WITH A GEARING DISADVANTAGE !!! Yes, the 325is has a 3.73:1 ring-and-pinion ratio whereas the M3 has a 4.10:1.
Doing nothing other than putting a 4.10:1 differential in a 325is will instantly make it faster than a stock M3 except for top speed.
How is this possible, you may think, because the M3 has 192 horsepower compared to 168 for the 325is?
This is where people's thinking goes wrong about what makes a car fast:
It's not how much horsepower the engine makes; It's better explained by the power-to-weight ratio (the car's weight divided by the engine's horsepower). But since the M3 and the 325is weight about the same, that STILL doesn't explain how the 325is with 24 less horsepower can outrun the M3.
The answer is in the area under the power curve of the engines. You can't accelerate all the way from zero to whatever with the engine always at the peak power RPM... so the shape of that Horsepower vs. RPM graph determines how much power goes to the wheels in real-world acceleration runs. The six-banger power curve is fat while the M3 is more like a spike, typical of a peaky twin-cam four. The area under the power curve of the six-cylinder is greater than the area under the power curve of the four cylinder, for the total RPM range used in accelerating. That's why the 325is is faster when you give it the same gearing.
Later,
&lt;img src=&quot;http://kcrealtime.com/dyno-max_900_hp.gif&quot;&gt;
KC Ron Carter is offline   Reply With Quote
Old 01-02-2005, 05:54 PM   #6 (permalink)
AmaRu is an unknown quantity at this point
Send a message via MSN to AmaRu Send a message via Yahoo to AmaRu
My Webpage
Later,
[snapback]262816[/snapback]
Wow.. ok einstein, just grab a chip like someone above said it is pointless to drop money into an eta.. I think a chip makes a very noticeable difference you'll enjoy a cheap mod like that, i know i did. Some advice the best chip you can get is from MarkD and im not just saying this because he is based out of Toronto (where i am) there have been tests, many reviews, and group buys from more than one e30 forum (i.e r3v) his software is also cheaper.. if you want more info come onto http://www.maxbimmer.com and ask around. Hope that helps
Good luck
AmaRu is offline   Reply With Quote
Old 01-02-2005, 10:23 PM   #7 (permalink)
Official Bimmerwerkz Biscuit Distributer
spiff325is's Avatar
Car: 00 M Coupe
spiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud of
Send a message via AIM to spiff325is
just take a driving class so you get better at driving, then power wont make a difference. you learn how to drive better with a more underpowered car.
I hate: people who haven't died yet that I hate.
L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc.
2000 BMW M Coupe - Dakar-II - S52
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
spiff325is is offline   Reply With Quote
Old 01-03-2005, 12:58 AM   #8 (permalink)
RealBMW 02's Avatar
RealBMW 02 is an unknown quantity at this point
Send a message via AIM to RealBMW 02
^^^agreed^^^^
spiff and I can keep up with much higher powered bimmers with our cars in relatively stock form since we can carry our speed through the turns and brake much later
<img src='http://files.unitedbimmer.com/ub.c/RealBmw%2002/Sig_ver2.jpg' border='0' alt='user posted image' />
1970 - 2002
Proud Memeber: 30+ year old car club
RealBMW 02 is offline   Reply With Quote
Old 01-03-2005, 06:51 PM   #9 (permalink)
My Webpage
Later,
actually my '89 is came with a 4:10 not a 3:73
Old 01-04-2005, 01:28 AM   #10 (permalink)
guywithblack88e30's Avatar
guywithblack88e30 is an unknown quantity at this point
[snapback]262385[/snapback]
not really that pointless there are things that work better on e then a i for instance turbo if you put turbo on e it will smoke a i cause of torque.
Member of got its raining(in Members Lounge) to 100, 237, 250, &amp; 300 pages club...
Member of 3 Pedel club...
Member of ran away from cop using DRIFTING not speed(ok a little speed)...
guywithblack88e30 is offline   Reply With Quote
Stock Engine And Tranny Horse Power Limit turbo03m3 M-Series (M1, M3, M5, M6) 2 12-05-2004 05:39 AM
Best Kind Of Headlight Bulb? all4isu 5-Series (E12,E28, E34, E39, E60) 6 10-18-2004 02:26 PM
Horse Power needed Portugal 3-Series (E36) 8 01-15-2004 05:37 AM
power pulleys, re they really that bad? the///man 3-Series (E36) 1 10-18-2003 09:12 AM
