Maintance - BMW Forum - BimmerWerkz.com
Old 01-11-2004, 12:01 AM   #1 (permalink)
lilboi is an unknown quantity at this point
I just recieved my 325is from my uncle. I want to know what i should change to keep the car running like it was brand new and not 16 years old.
This is what I got done so far:
NEW cat
New O2 sensor
spark plug wires good
spark plugs good
Suspension good
oil okay
coolant good
What i think i need to replace or tune:
Valve gasket
Valve adjustment
fuel filter
I do have a new valve gasket, but its is bent little but, very little. Is it still useable?
If you can't afford it, make it!
<img src='http://anewbeginning.home.mindspring.com/325is/101-0179_IMG1.jpg' border='0' alt='user posted image' />
lilboi is offline   Reply With Quote
Old 01-11-2004, 09:54 AM   #2 (permalink)
The big issue if it is a 6 cylinder it has a rubber timing belt.
That belt if it breaks will make junk of the engine.
It is normally changed every 50,000 miles or every 5 years.
Make sure it is changed or get someone to do it.
Congratulations and welcome.
Here is a link to BEN, BMW E30 Network, lots of good information on e30s there.
http://www.bmwe30.net/cgi-bin/datacgi/data...report=sections
Later,
&lt;img src=&quot;http://kcrealtime.com/dyno-max_900_hp.gif&quot;&gt;
KC Ron Carter is offline   Reply With Quote
Old 01-11-2004, 10:36 AM   #3 (permalink)
tankman is an unknown quantity at this point
Send a message via AIM to tankman Send a message via Yahoo to tankman
hmmm mayby the air filter and fuel filter
86 325es (rockin the one speaker tapedeck tunes)
85audi 4000s Quattro a few goodies e-codes and tunes(and a pimp misfits sticker on the back booyah)
--justin
Bend(sunriver) Oregon
tankman is offline   Reply With Quote
Old 01-13-2004, 01:53 AM   #4 (permalink)
pogiboy9 is an unknown quantity at this point
Send a message via AIM to pogiboy9 Send a message via MSN to pogiboy9
CHANGE OIL, Check your gaskets. Change Coolant and Clean water. if not you could be where i'm at for just driving it. but yeah change that oil if your already iffy with it. Oil change isn't even expensive or hard to do so go for that. Simple *mod would be the Cone Intake. And if u wanna do a big mod. From a fanatic i met at the junkyard. The "Orca" mod
pogiboy9 is offline   Reply With Quote
Aproximate maintance costs mole 3-Series (E36) 18 03-11-2004 02:43 PM
