MAF conversion? - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 03-04-2004, 02:25 AM Thread Starter
1985bmw325e is an unknown quantity at this point
SMT6??? MAF??? what the hell is this? can someone tell me what this is and what it does?? i'm new to this bmw scene, i dont know much about it, so someone plz enlighten me about this
1985bmw325e is offline
post #2 of 8 (permalink) Old 03-06-2004, 01:03 AM
I converted my e24 to a Spit Second MAF.
OE was a AFM, Air Flow Meter.
Now a MAF, Mass Air Flow.
MAF uses a hot wire to determine air flow so it has little restriction to air flow.
It provided a lower max torque point and provided 21 HP pop.
Here is my MAF from Split Second
The controller is in the glove box, and is indexed to allow me to play with settings and get back to smooth running.
Here is the Ford 65mm MAF and it is made in JAPAN.
If this engine was shiny enough to reflect,
you would see me smiling while taking the pictures.
Cause I really like the output of the MAF.
Six hours, DIY, including the indicator and can switch back to AFM in 2 minutes, Two screw clamps on MAF, two quick electrical connectors and the OE connector is tie wrapped back out of the way.
OE is
3430cc M30
Motronic
DME II
92x86, 8.0:1
185bhp/5400rpm
214lb.ft/4000rpm
I own a dyno so here is the output at the wheels.
HP loss in transmission and differential 25%
So 222 HP at shaft is the result.
I am using the J C. chip also, a 3.71 ratio, with 265 Getrag.
The sweet spot of the m30 is now at 2200rpm where it was at 2800rpm.
That is the point where the rumble of the exhaust resonates in frequency with the intake. On the unmodified it is only seen on the cold mornings when the fuel system adds a little more fuel and the cold air is giving it's all.
I really like it.
My Cartech RRFR installed and test in advance of the M102 12 psi turbo.
I hope to sneak up on a few Stangs and Meros on the Dyno.
My source:
http://www.bmpd.com/bmw/parts/catalog/engine_32.shtml
Later,
<img src="
KC Ron Carter is offline
post #3 of 8 (permalink) Old 03-06-2004, 02:10 AM
Mr.BMW is an unknown quantity at this point
$525! EEEEEP!
Mr.BMW is offline
post #4 of 8 (permalink) Old 03-06-2004, 04:24 AM
its actually 895-925
sp0rky is offline
post #5 of 8 (permalink) Old 03-06-2004, 07:54 PM
I told the wife it was .9 k in US dollars.
Sounds better that way.
Later,
post #6 of 8 (permalink) Old 03-07-2004, 10:56 PM Thread Starter
nice conversion. Do you really feel the difference in driving?
post #7 of 8 (permalink) Old 03-08-2004, 12:36 AM
Yep it makes torque, and torque wins races.
Horse power just sells cars.
I installed the MAF as a step to putting a turbo on the m30.
Here is my Metric Mechanic head sitting in the basement.
That and the KKK27 Turbo should make some real deal power.
Here is a link to the same base engine with 500 k making 600 hp with 23 psi of boost, with out my better electronics and swirl porting.
http://eurospeed.net/forum/viewtopic.php?t=228
This is my stang and mero monster eater.
Later,
<img src="
post #8 of 8 (permalink) Old 03-10-2004, 11:57 PM
350z
KC i love your cars dude! you are so smart and have some badass cards hats off to you!
David
bigred318 is offline
five lug conversion driftin325s 3-Series (E21, E30) 4 09-21-2005 04:47 PM
which engine is easier to mod for the E21? AE101 3-Series (E21, E30) 5 04-01-2004 08:43 AM
Completed my Valeo to Bosch alternator conversion MOTRSPRT 3-Series (E36) 5 01-26-2004 07:16 PM
Early vs. late 320i compatibility babzenuda 3-Series (E21, E30) 4 01-10-2004 03:32 AM
5 SPeed Swap PLEASe HELp ME nukeall 3-Series (E21, E30) 1 12-11-2003 12:36 PM
