M50B25 from e34 to e30 problem - BMW Forum - BimmerWerkz.com
post #1 of 2 (permalink) Old 07-19-2007, 03:57 AM Thread Starter
Toninho is on a distinguished road
I came here in hope that you nice people might help me.
I've done a engine swap, M50B25 from E34 to E30.
I had 2 engines M50B25 to make 1 good engine.
Now, swap is done, but engine runs on 3 cylinders.
When i switch off Luftmassemeser (MAF) engine runs twitchy but when i rev it it runs on 6 cylinders.
I tried to put LMM, Lerluft ventil and ECU from friends car that runs OK,
but the same thing is happening.
Is it possible that one of the engines that i took the LMM and ECU have a Bosch, and this one in the car had Siemens electronic and wires layout?
Or you think it might be something else?
E30 that i build is for drifting.
Thank you,
Toninho is offline
post #2 of 2 (permalink) Old 07-30-2007, 01:43 PM
BMWJNKY's Avatar
BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute
How did the engine run before it was pulled from the E34? Did you do a cylinder leak down test to make sure the engine was in good condition before it was installed into the E30?
If the engine ran well before it was pulled check the grounds for the coil packs. Make sure there is no dirt, oil or paint between the grounding surfaces. Also check the spark plugs and make sure they arn't platinum. Plat. plugs tend to foul out very easy on the older engines, I recomend using the factory Bosch plugs.
BMWJNKY is offline
e30, e28, and e34 Haynes Manual Download Cruzin 323is 5-Series (E12,E28, E34, E39, E60) 5 01-10-2011 12:39 AM
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 07:26 AM
M50B25 from e34 to e30 problem Toninho 5-Series (E12,E28, E34, E39, E60) 0 07-19-2007 03:57 AM
e30, e28, e34 Haynes Manual Download Cruzin 323is 3-Series (E21, E30) 2 04-10-2006 12:33 PM
E34 trans prog problem exacerbated electronblue 5-Series (E12,E28, E34, E39, E60) 5 03-02-2006 11:07 PM
