Luke, use the torque.... - BMW Forum - BimmerWerkz.com
Old 09-06-2006, 09:50 PM   #1 (permalink)
Car: Opening soon:
So many people talking about making an ETA rev higher, and putting in lower gears trying to make more "power", the fact is no body seems to know how to use what they have, to make what they have work better for them, and why torque is more important than HP.
ETA motors put out great torque, so USE IT. Putting in a lower gear differential doesn't help an ETA build power, it's an old school method that works by turning RPMs into torque. That is what the transmission and differential does, it turns the motors low torque and high RPMs into putting more torque at a lower RPM into the wheels. Loosely translated it means if you have lots of lower gearing you are going nowhere fast with tons of torque. Think of riding a mountain bike, starting off in first gear, you'll peddle like crazy (building loads of torque at the wheel) but you are not going fast or covering any real distance. However you needed less leg torque, just RPMs. Put the bike into a higher number gear and you need loads of leg torque to start off but now you can go faster. You need to find the gearing that makes the most of the available power (leg torque) and trading that to obtain most distance traveled with the most wheel torque.
This same principle applies to cars too. Since lower gears will up the torque it will also drop the useable torque RPM range. (staying in each gear less and shifting more) You must gear your car correctly for the rpm range to make the most of the torque your motor is building with the greatest amount of distance with out going out of your torque's RPM window.
What to do?
Now you should be thinking "So putting lower gears into an ETA (or any high torque, low rpm motor) is shooting myself in the foot, ok, so how do I build more low end torque? A large turbo?" No, a smaller turbo, another misconception. Turbos are, simply put, a torque multiplier. Larger turbos require great amounts of exhaust (aka RPMs) to spool up. Something the ETA doesn’t do well and is out of the ETA's useable torque range. (what good is it adding torque in the higher RPM range when there is no torque to add to?) The answer: Install a smaller quicker spooling turbo to increase the low end torque you already have.
With the quicker spooling turbo you "boosted" your torque in the motors torque rpm window (power band) Now lets jump back to the bike metaphor, this means with the turbo you have pumped up your legs (more "leg torque") and now you can use the upper gears to start off moving faster using "leg torque" getting the most out of gearing and still putting that power to the ground. Now since you have more power in the lower RPM range you also spread out your power band because you are moving faster at a lower leg RPM. In the car it means you can use that higher geared differential to turn your motor's higher torque into more wheel torque at lower RPMs, aka: More power and speed.
This principle is why that screaming 10,000 rpm, huge turbo powered honda seems to have so much "power" In reality it doesn't, the turbo is dumping torque into the upper RPMs just so it can trade it off for lots of wheel torque. It's also why you see so many dead hondas (and other high RPM cars) too... They are asking the motor to spin faster which is very violent and detrimental to a engine with so many moving parts. The wankel rotary motor is perfect for high RPMs (less moving parts) but that is another story....
Now I hope some of you get this and understand why torque is more important than HP. And also explain why a 180hp 460 ft/lbs of torque huge diesel powered truck can actually move very fast. Also why lower gears makes cruising on the highway going 60 mph @ 3500 RPMs very stupid because your motor is just spinning it's legs and going "nowhere fast".
Old 09-07-2006, 01:25 AM   #2 (permalink)
JoeMadoo's Avatar
JoeMadoo is on a distinguished road
Send a message via AIM to JoeMadoo Send a message via MSN to JoeMadoo Send a message via Yahoo to JoeMadoo
I agree. Tell that to krautman.
86 Alpine White 335is M30 Swap <br>My Car Domain
ASE L1 Smog Certified
JoeMadoo is offline   Reply With Quote
Old 09-07-2006, 01:26 AM   #3 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
HP == fake number to please the public invented by marketing people.
Torque == the true driving force of a vehicle.
For those who want an even further lesson, whom may not understand...
HP = Trq x RPM / 5252
Some people / texts say 5250.. but thats hardly going to change the outcome..
So, thusly, if you have a given motor, making 150 ft/lbs torque at 5400 rpm, and you would be generating:
150 x 5400 / 5252 = HP
You'd be "making" 154.23HP @ that RPM.
So, hondas which appear to have 600hp at 10,000 rpm, are only making 315 trq.
VS a bmw that makes 600hp @ 6,500 rpm is making 484 trq at less rpm.
Trq is the actual work twisting your wheels around, so to make more, at lower rpms... and for more overall rpms.. means to go faster.
So, all the 900hp supras, bah.
I'd take a 500hp m5 any day.
Old 09-07-2006, 03:09 AM   #4 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
Great Writeup!! i couldnt agree more, and yet i think joe is the confused one.
thats right tell me what i already know and agree to??.....yess....thats it what was the point of this comment joe?
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 09-07-2006, 03:46 AM   #5 (permalink)
Retired administrator
triggrhaapi's Avatar
WRONG!
The advantage of a higher revving engine (that can keep peak torque up at higher RPM) is that you get the same torque, same engine load (i.e. same gear) but more speed out of the gear and more time spent in peak torque at the lower engine load, where the engine can accellerate more easily. That's why it's better to have a midrange peak that pulls hard to the top. You can get very insane accelleration out of an 8000rpm Supra engine. Believe me. 900hp Supra will stomp 600hp M5 like it was standing still.
EDIT: Video evidence: 811whp 8000rpm Supra (black)vs 620whp with higher torque than the other (camera)
YouTube - Brad D's 800rwhp Supra vs Dan's 620rwhp Supra.
Addicted to Speed Since 1997
Old 09-07-2006, 03:51 AM   #6 (permalink)
gotKRAUT's Avatar
Originally Posted by triggrhaapi
WRONG!
exactly, see this is the point where i lost joe the other night and i think thats what he is reffering to with his little quip...
Kyle Sutherland
1995 BMW 540i/6:
Old 09-07-2006, 04:34 PM   #7 (permalink)
nukeduster's Avatar
WRONG!
Different turbo setups from the same motor.. i said same peak hp.. thats 200whp difference, the trq curves are still going to be vastly different(and possibly inefficient)
The 2005 vs the 2006 caddy CTS-V for example, has identical trq and hp numbers, but it has more torque, more of its powerband by swapping into a LS-2 motor from the LS-6.
Its more drivable power to torque down-low..
more hp @ the top = higher top speed/ability to pull better at higher speeds..
BECAUSE its in its efficiency range @ said rpm @ said speed.
Quarter mile times should probably be pretty close between those two vehicles, given equal drivers and conditions.
You also didnt read completely what i said.. more torque downlow, that stays consitent thru the whole rev range WILL be faster..
Look no further then the Audi le mans r10 diesel.. it has waves of torque the other gasoline engines didnt, and because of proper tuning, maintained the torque thruout its rev range, keeping it the absolute dominant racecar on the track. by LEAPs and bounds.
If you want race track top speed power, peak up high.. if you want 1/4 mile power and real life power, torque as low as you can, for as long as you can.
Old 09-07-2006, 04:52 PM   #8 (permalink)
nukeduster's Avatar
Brake Mean Effective Pressure (BMEP) is another very effective yardstick for comparing the performance of one engine to another, and for evaluating the reasonableness of performance claims or requirements.
For completeness, the definition of BMEP is: the average (mean) pressure which, if imposed on the pistons uniformly from the top to the bottom of each power stroke, would produce the measured (brake) power output.
Note that BMEP is purely theoretical and has little to do with actual cylinder pressures. It is simply an effective comparison tool.
If you work through the arithmetic, you find that BMEP is simply a multiple of the torque per cubic inch of displacement. A torque output of 1.0 lb-ft per cubic inch of displacement equals a BMEP of 150.8 psi. So a very practical way to calculate BMEP is:
BMEP = 150.8 x TORQUE (lb-ft) / DISPLACEMENT (ci)
(equation 8)
This tool is extremely handy to evaluate the performance which is claimed for any particular engine. For example, the 200 HP IO-360 and 300 HP IO-540 Lycomings operate at a BMEP of about 163 psi. (1.08 lb-ft of torque per cubic inch) at peak power and slightly more at peak torque. That is a respectable figure.
For contemporary naturally-aspirated, gasoline-fueled, two-valve-per-cylinder, pushrod engine technology, a BMEP over 200 PSI is quite difficult to achieve and requires a serious development program and very specialized components.
The upper end of the normally-aspirated BMEP spectrum is shown by these two race engines.
One was a 358 cubic inch circle track motor (gasoline-fueled, 2-valve, pushrod V8) which made 531 lb-ft. of torque at 6400 RPM (647 HP) and 503 lb-ft of torque at 7600 RPM (729 HP). Those data points represent BMEP figures of 223.5 at peak torque and 211.4 at peak power. Those numbers are truly excellent, and require very-highly developed components.
The best by far that we have seen was a 268 cubic inch drag-race motor (gasoline-fueled, 2-valve, pushrod V8) which made 413 lb-ft of torque at 7800 RPM (613 HP) and 372 lb-ft of torque at 9200 RPM (652 HP) for BMEP figures of 232.7 at peak torque and 209.6 at peak power. The 232.7 number is astonishing at any RPM. The 209.6 figure at 9200 RPM is nothing short of phenomenal for a two-valve pushrod engine.
To appreciate the value of this tool, suppose someone offers to sell you a 2.8 liter (171 cubic inch) Ford V6 which allegedly makes 230 HP at 5000 RPM, and is equipped with the standard iron heads and an aftermarket intake manifold and camshaft. You could evaluate the reasonableness of this claim by calculating that 230 HP at 5000 RPM requires 242 lb-ft of torque (230 x 5252 ÷ 5000), and that 242 lb-ft. of torque from 171 cubic inches requires a BMEP of 213 PSI (150.8 x 242 ÷ 171).
You would then dismiss the claim as preposterous because you know that if a guy could do the magic required to make that kind of performance with the stock heads and intake design, he would be renowned as one of the preeminent engine gurus in the world. (You would later discover that the engine rating of "230" is actually "Blantonpower", not Horsepower.)
Old 09-07-2006, 06:14 PM   #9 (permalink)
Do you want to see what that supra did to a Venom Viper? Or a S/C Vette Z06? It's brutal.
I was simply going for a torque comparison. The 620whp supra made like 20lb/ft more torque than Brad's car, but it wasn't as useful because the engine didn't rev high. Same case with the Venom Viper (except more along the lines of 100lbs/ft more tq) and the same results (actually the 620whp supra whupped the Venom Viper too)
Torque is also not always your friend, keep in mind. Peaking later in your rev band makes launching easier, and makes boost come in more controllably during upshifts. Fact O' life my friend. Torque is the mortal enemy of traction.
Old 09-07-2006, 10:20 PM   #10 (permalink)
Car: Opening soon:
There are too many other factors to take into account to give an accurate account of how power is used and transferred: Power to weight ratio, transmission gearing, the balance of weight from front to rear, suspension, and tires. If you want to be fare in an example of better use of power use, then you must compare two cars of identical makes and models to see the benefits of any modification. To use torque, you must gear in order to make use of it and not waste it.
Old 09-07-2006, 10:47 PM   #11 (permalink)
DIRTE30's Avatar
DIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond repute
Send a message via Yahoo to DIRTE30
You guys are all correct in one aspect or another. The real trick with todays technology is achieving a movable torque band! Having low end grunt when it's needed and high end HP when it comes time! All you Vanos haterz out there need to wake up a smell the possiblities that come along with that kind of tech. Combine VVT type of tech. with Direct injection and variable vane turbos and you can have it all. Not to mention the new incredible CVT or DSG type trannies out there that will allow infinitely variable ratios and or lightning fast gear changes to keep your little electronic bad ass right in the sweet spot, right when you need it! The days of choosing one way or the other torque monster VS. high revving race motor are all but gone and in the near future, as much as it may pain me to say it, we will all be talking about how inefficient the internal combustion engine always was compared with the electric motors that will be replacing them. I hate to see em go, but I think that we can still have just as much fun with electric motors, if we have to.
DIRTE30 is offline   Reply With Quote
Old 09-07-2006, 11:09 PM   #12 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Sweet thread, sweet thread.
Turkey Fleet Bond Holder
Old 09-07-2006, 11:35 PM   #13 (permalink)
1. Low end grunt is not always a good thing, and in fact is usually counterproductive to such things as launching the car.
2. You're out of your mind if you think that VVT can make a car that has low end torque and can also string out to high revs. Closest motor I know of is the Z06 motor, and that doesn't actually rev very high at all, and doesn't use any fancy technology to achieve what it does, just good old brute force.
3. Electric motors fucking suck. They suck because they are terribly inefficient in terms of power consumption and power storage. Batteries lose energy as they sit. Fuel does not lose it's potential energy by sitting.
I will give you this, alot of those factors come into play, but the fact of the matter is that every single supercar out there has a midrange torque peak and is designed to pull hard to a high RPM at the top. Koenigsegg, Ford GT, Saleen S7, McLaren F1, Pagani Zonda, Radical SR8, Ferrari Enzo, Ferrari F50, Ferrari F40, all of these have engines that are designed to spend as much time in the lowest engine load possible and get the highest speed out of each gear. Some cars are designed to be more torquey in their delivery and have a lower revving engine, such as the Koenigsegg, Saleen and GT. Other cars have a more balanced torque/hp delivery, such as the Pagani Zonda and the Mclaren F1, others still have a higher revving, peakier engine, such as the Ferraris, and the Radical SR8. Regardless of how it goes, all of these engines hit peak around the middle of their rev range, which is the point I was originally making. Torque is all fine and good but delivering it in the most efficient way possible is the end goal.
The Eta motor, the original subject of this thread is a great example of a motor that was not meant for sport. It peaks it's torque down low and provides a vast area under the torque curve, which makes for elegant and efficient travel, yes, but does not do you much good when you want to go fast. The i motor, by comparison, is high revving (and only by comparison, believe me) but is actually a more middle of the road kind of engine. It produces nearly identical horsepower and torque figures, and much like a scaled down S50, peaks at around 4200 rpm and pulls hard to around 7 or so when chipped. This is by no means "peaky," when compared to a high strung motor like, say, an S2000 motor, which peaks at more like 6500rpm and goes to 9k.
The Supra is a good example of a middle of the road boosted engine. Despite it's higher revving, it makes it's peak power in the middle of it's rev range, even when boosting on a giganto mondo turbo. Alot of people talk shit on them, but until you've driven one, you have NO idea what they are capable of. People just think they're slow because of the stupid people that drive them. Get a good driver in a good Supra and you'll never see them again.
Old 09-08-2006, 01:48 AM   #14 (permalink)
nukeduster's Avatar
1: launch technique.
2: porsche variocam
3: they produce no pollution, have fewer moving parts, require no external lubrication, and doesnt suffer from reaching the maximum moment of inertia that piston driven motors do before pistons disintegrate. which means, it really has no realistic rpm limit.
3.2: actually, fuel does break down sitting.. at actually a faster rate of decay then li/ion, li/manganese dioxide which have a shelf life of over 10 years with ~2-5% decay / year, with no /little voltage drop occuring over time. true, old lead cathode batteries exhibit this, but technologies are changing, very very quickly.
Ethanol mixed fuel, has a shelf life of appx 60-90 days if not stored in an air tight metal container as it is very hygrophobic.
Old 09-08-2006, 11:31 AM   #15 (permalink)
DIRTE30's Avatar
Thumbs up
524TD Manual or Torque values DieselBeamer 5-Series (E12,E28, E34, E39, E60) 1 02-26-2006 02:05 PM
Torque Converter - need help 540sport 5-Series (E12,E28, E34, E39, E60) 1 01-19-2006 06:50 PM
318 Torque Mod Question fushuman 3-Series (E36) 5 10-27-2004 08:25 AM
First look and info on the 2005 Acura RL AWD! AZ325Ci Other Rides 2 06-23-2004 09:23 PM
