Originally posted by daxsandman@Nov 23 2004, 08:33 PM Would a 1.25in drop all the way around on a 1991 318is look alright with 17in rims with 205/40/17 tires? Im getting my car lowered this weekend and i was just wondering, also do i need camber plates for the drop also or would it be fine, im just trying to make sure if ill get even tire wear cause where i got my tires will do the alignment for free if there are no camber issues. [snapback]236323[/snapback] |
itll look SLEEKER and handle much better on all corners and avoiding things in the road.
one thing NOT to overlook is to make sure the oil pan has the bolt protected by either grinding away the un-neccessary parts ( i read this today on this very board and im planning on checking mine tomarrow)) also the rear differential may be at risk ..
so avoid all holes and rises in the road (wich will make you all the more happy about your new suspension too.
and after i lowered mine i parked too close to a parking wheel stop and ripped off the front air dam ( wich i snapped back on and had to re-screw) very embarrasssing...
ghead
member of the <span style='color
range'>3 pedals club</span>
range'>195,000+ mile club</span>
<span style='color:red'> its the ones who cant even drive slow that think i cant drive better fast..</span>
