| Low Beam Check Relay I have a 1990 325ic and the low beams do not work (they work with the high beams) I understand this is a multi-filament lamp and the fuses are good so I, again (did this six months ago) suspect the low beam relay. However, there is a low beam check relay as well, and can someone tell me what this does. |
