Loss of power - BMW Forum - BimmerWerkz.com
Old 08-30-2006, 12:52 AM   #1 (permalink)
JoeMadoo's Avatar
JoeMadoo is on a distinguished road
Send a message via AIM to JoeMadoo Send a message via MSN to JoeMadoo Send a message via Yahoo to JoeMadoo
Loss of power
What would cause an eta to have NO power at 2000 rpms but run great anywhere else? Typically in 3rd, 4th, and 5th gears.
86 Alpine White 335is M30 Swap <br>My Car Domain
ASE L1 Smog Certified
JoeMadoo is offline   Reply With Quote
Old 08-30-2006, 12:39 PM   #2 (permalink)
WardJ's Avatar
WardJ is on a distinguished road
Send a message via AIM to WardJ Send a message via MSN to WardJ Send a message via Yahoo to WardJ
dirty spark plugs?
'85 325e
'Arrest Me Red'
mods to come:
Window Tint
New Badges - Check!
Muffler - Check! - Ansa free flow
New Radio
Sport Shocks - Bilstein
Keyless Entry + Alarm - BMW Security Systems
Power Flow Intake
THE founding member of "i don't hate on del"
WardJ is offline   Reply With Quote
Old 08-30-2006, 03:41 PM   #3 (permalink)
JoeMadoo's Avatar
No the plugs are fairly new and good shape.
Old 08-30-2006, 05:09 PM   #4 (permalink)
DIRTE30's Avatar
DIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond repute
Send a message via Yahoo to DIRTE30
Check your intake boot for tears. Also check for vac. leaks in general. How long has it been since you cap and rotor were checked? Sounds like it may be an secondary ignition issue.
DIRTE30 is offline   Reply With Quote
Old 08-30-2006, 05:47 PM   #5 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
the fact that its an Eta should be the answer
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 08-30-2006, 06:16 PM   #6 (permalink)
JoeMadoo's Avatar
I will check it out in a bit. What kind of bimmer do you have again kraut?
Old 08-30-2006, 08:23 PM   #7 (permalink)
Car: Opening soon:
Dead spot in the AFM, could cause this. Is your car chipped?
Old 08-31-2006, 01:53 PM   #8 (permalink)
JoeMadoo's Avatar
Its not my car, but his has a dinan chip.
Old 08-31-2006, 03:59 PM   #9 (permalink)
Rfitz25's Avatar
Rfitz25 is on a distinguished road
yeh I was gonna say AFM
hard to rebuild
most rebuilds suck
new ones expensive
Im told, if you can get the little arm to slide on a new surface out of the worn groove you can get clean readings again for another 10 years.
One guy did this by changing the center of rotation slightly so the arm sticks out a bit more, then the arch is only slightly wider but you get whole new surface to wear out. he had to remove the arm and cut or grind it out somehow.
I gave up and bought a new Bosch unit after returning two rebuild units.
If you take it out and hook it up to a meter you should be able to see the dead spot if there is one. You just have to take a bunch of readings (20 min) at small increments. If its that bad you might even be able to see it while in the car, just stick your finger in it,LOL, dont screw up the wind vane sensor ball thingy. Oh yeh check that out too it could be bent.
I think haynes has the reading min max. Dont be fooled by the WOT reading I think its very different than the closed position to close to WOT.
Oh ye the incriment are like really small like .001 ohms per degree of rotation
Dont break the seal and open the electronics unless you know its toast and want to try and rebuild it. a last resort only.
Good luck.
PS I just put in Castrol GTX 10W-40 in my new i motor yeasterday, nice, and Redline MTL in the gerbox today. so far so good.
Shifts a little smoother bu I still think my syncros are going.
and who knows where to get the rebuild kit for shift linkage?
Its either that or a whole SSK. runnin out a budget LOL
Cheers,
Richard Fitz
'87 325is Delphin Metalic
Rfitz25 is offline   Reply With Quote
loss of power in my 325iX 325iXer 3-Series (E21, E30) 1 08-23-2006 11:05 PM
Sputtering / Loss Of Power streetdreams 3-Series (E36) 9 02-18-2005 03:35 PM
Best Kind Of Headlight Bulb? all4isu 5-Series (E12,E28, E34, E39, E60) 6 10-18-2004 02:26 PM
power pulleys, re they really that bad? the///man 3-Series (E36) 1 10-18-2003 09:12 AM
