A Little Help Requested - BMW Forum - BimmerWerkz.com
Old 01-23-2005, 06:20 PM   #1 (permalink)
wcleafs's Avatar
wcleafs is an unknown quantity at this point
Spent all day yesterday changing out my old front struts on my 320i for new air gas, I also changed bushings and tie rods. the car use to have the 80k shimmy which is now gone. steering is tight and everything feels great....until you hit around 90 to 100 kph I now get a bad vibration in the steering. Not sure what is wrong as all pieces are in their correct location. Perhaps something not tightened down correctly?
Or...??? (enter you ideas here)
Thanks ghead
GO LEAFS GO
wcleafs is offline   Reply With Quote
Old 01-23-2005, 06:21 PM   #2 (permalink)
Hoppy's535i's Avatar
Hoppy's535i is an unknown quantity at this point
thrust arm bushings
<span style='font-size:11pt;line-height:100%'><span style='color:blue'> theres no replacement for displacement </span></span>
Hoppy's535i is offline   Reply With Quote
Old 01-23-2005, 06:24 PM   #3 (permalink)
try balancing your tires, or see if a front wheel is bent. if that doesnt help you may need to turn your rotors
Old 01-23-2005, 10:01 PM   #4 (permalink)
sniady is an unknown quantity at this point
i'd start out getting the tires balanced
sniady is offline   Reply With Quote
Old 01-23-2005, 10:04 PM   #5 (permalink)
///M Dream's Avatar
///M Dream is an unknown quantity at this point
its almost deffinetly unbalanced tire(s)
///M Dream is offline   Reply With Quote
Old 01-24-2005, 08:23 PM   #6 (permalink)
wcleafs's Avatar
Thanks for the responses
It does appear to be the tires, changed my tires back to the original wheels and ta da shimmy gone. Still have some play in my wheel bearings but can take care of that later.
So must balance the other tires now.
Another question, suggestion on rim sizes for the 320i , will 14 work with spacers?
Dont want to go bigger than that really.
Cheers and once again thanks for the help
GO LEAFS GO
Old 01-26-2005, 02:35 PM   #7 (permalink)
pommeree is an unknown quantity at this point
You'll definately want to retorque if not repack your front bearings if they need it. They're easy to retorque (retighten essentially) And total replacement can be accomplished in a few hours. Just remember to use an a#$&-load of grease.
Other shimmy sources include lower control arm bushes (easiest/cheapest to replace whole arm) Upper strut mounts, front sway bar bushes, steering rack bushes.
Good luck,
E.
pommeree is offline   Reply With Quote
as requested by ski..... show us your pics. fatty Picture Showroom 45 05-22-2004 06:28 PM
Planned upgrades for E39 540i...input requested mrogers 5-Series (E12,E28, E34, E39, E60) 22 05-04-2004 07:51 AM
