Light Replacement - BMW Forum - BimmerWerkz.com
Old 09-29-2004, 03:02 PM   #1 (permalink)
mysticguy04 is an unknown quantity at this point
Send a message via AIM to mysticguy04 Send a message via Yahoo to mysticguy04
The light on my automatic shifter has burnt out.
How do I rplace it? I was afraid to try and pry off the shifter cover. Do I have to take the center console apart or does the shifter cover snap off?
mysticguy04 is offline   Reply With Quote
Old 09-29-2004, 03:49 PM   #2 (permalink)
flipsgonetopless's Avatar
Car: 1991 318is
flipsgonetopless is an unknown quantity at this point
Send a message via MSN to flipsgonetopless
I just replaced mine two weeks ago, all you have to do is pop out the plastic cover and then put in on Nuetral (apply your hand brake first). The bulb is located in the black socket but it has little locks on you need to release it comes down and viola' you can replace your bulb. Hope this helps should only take you about 10 minutes maximum.
flipsgonetopless is offline   Reply With Quote
Old 09-30-2004, 08:44 AM   #3 (permalink)
[snapback]201527[/snapback]
Thank you for the tip! :}
Is there a trick to taking off the cover? I'm afraid I'll crack it! Did you use a screwdriver? Pry corners or middle?
thx
Old 09-30-2004, 09:08 AM   #4 (permalink)
Originally posted by mysticguy04+Sep 30 2004, 07:44 AM--><div class='quotetop'>QUOTE(mysticguy04 @ Sep 30 2004, 07:44 AM)</div><div class='quotemain'><!--QuoteBegin-flipsgonetopless@Sep 29 2004, 02:49 PM
I just replaced mine two weeks ago, all you have to do is pop out the plastic cover and then put in on Nuetral (apply your hand brake first). The bulb is located in the black socket but it has little locks on you need to release it comes down and viola' you can replace your bulb. Hope this helps should only take you about 10 minutes maximum.*
thx
[snapback]201977[/snapback]
[/b][/quote]
Okay, I/m making progress! I popped the cover off and put in neutral, problem is that I don't see a bulb anywhere???
Old 09-30-2004, 09:17 AM   #5 (permalink)
87 325iS is an unknown quantity at this point
It's on the left side of the shifter, connected to it. It's like a little black tube with a hole in the top. Just reach under it and the bulb slides out.
Amberfire 2000 Dodge Dakota R/T
Rusted, fallling apart Alpine White 1987 325iS - Gone but not forgotten
<img src='http://img.photobucket.com/albums/v255/HeilSova/Sig.jpg' border='0' alt='user posted image' />
87 325iS is offline   Reply With Quote
Old 09-30-2004, 10:25 AM   #6 (permalink)
[snapback]201989[/snapback]
I see an empty little hole at the base of the shifter on the right side, could that be it? Could it be that and there is just no bulb in it? Is the bulb long and skinny?
There is a liitle black clip on the left side directly under the prnd321 colum but no lite assembly.
Dash Light Replacement 94325is 3-Series (E36) 5 10-04-2005 08:16 PM
Tail Light Replacement ozzy 3-Series (E46, E90) 3 08-10-2004 08:07 AM
Reverse light cover Replacement? Kodiak 3-Series (E46, E90) 0 07-13-2004 08:20 PM
brake pad replacement light sie1978 3-Series (E46, E90) 4 01-01-2004 04:56 PM
