Leaky Clutch! - BMW Forum - BimmerWerkz.com
Old 10-22-2004, 11:30 AM   #1 (permalink)
Hypnogaja's Avatar
Hypnogaja is an unknown quantity at this point
My transmission bled to death last weekend and I completely lost my clutch (no pressure).
Added some fluid and noticed that every time I pressed the clutch down, fluid would gush from the transmission :
It's coming from where the transmission bellhousing meets the engine (bad gasket) But I have no idea how to drop this transmission (i'm so used to the chevy 2-bolts and it's dropped)
Should I even attempt to try to replace this gasket, or should I take it to a pro?
'85 318i
5-spd manual
Hypnogaja is offline   Reply With Quote
Old 10-27-2004, 02:09 PM   #2 (permalink)
Hypnogaja's Avatar
ghead
Removed all bolts from bellhousing and all bolts from the driveshaft (incl. guibo), but the driveshaft wont drop!
How the @$# is this tranny supposed to come out? I'm afraid i might break something if I go any further w/o any help.
Old 10-27-2004, 11:42 PM   #3 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Before you take the trans out try installing a new clutch slave cylinder. About $40 and an hour to install and bleed.
My M50 Powered E30 Page
Old 10-28-2004, 02:10 AM   #4 (permalink)
Hypnogaja's Avatar
All my cylinders master&slave are fine, it was gushing from the front main seal. The seal is toast, so the tranny neds to come out (as soon as I figure out how to drop that #$@! driveshaft)
Old 10-28-2004, 07:21 AM   #5 (permalink)
'89 635 csi's Avatar
'89 635 csi is an unknown quantity at this point
I didn't think there was a seal where the engine meets the bellhousing.
Dave G.
'89 635csi
'86 528e - Sold
'84 528e - Soon to be 533i
'96 Jeep Cherokee 4WD
OO=[][]=OO
'89 635 csi is offline   Reply With Quote
Old 10-28-2004, 07:51 AM   #6 (permalink)
mr_fixit is an unknown quantity at this point
This really sounds like classic slave cylinder failure. An oil leak in the engine would have absolutely NO impact on the pumping up the clutch. If adding brake fluid and pumping restores clutch function - ITS NOT THE ENGINE SEAL.
When a slave cyliner fails, the brake fluid squirts out the end, past the seal and into the bell housing - this is classic. You should be easily able to tell brake fluid from motor oil (smell, color etc.)
mr_fixit is offline   Reply With Quote
Old 10-28-2004, 10:13 AM   #7 (permalink)
[snapback]220021[/snapback]
[/quote]
Dave G.
'89 635csi
'86 528e - Sold
OO=[][]=OO
Old 10-28-2004, 01:01 PM   #8 (permalink)
Hypnogaja's Avatar
oops
Guess i'll have to put all the bolts back on the tranny and try replacing the slave cylinder.
Leaky Valve Cover Gasket nookatee 3-Series (E36) 4 07-11-2005 01:37 AM
Leaky Girl. 007ben 3-Series (E36) 6 12-18-2004 10:59 PM
Leaky shocks ArchaicAngel 3-Series (E46, E90) 0 07-12-2004 03:46 PM
