That's weird. Mine didn't have any plug-ins like that. I had constant power, a ground, an ignition 1, an ignition 2, starter wire, on-off switch, led light, hood pin switch, brake shut off wire, tach input wire, headlight wire, horn wire, and the door input wires. Everything is hard wired. I'd call tech support and see if there is another way to initialize your remote, or spend the money to have someone do it that knows more than us.
