kangaroo fuel - BMW Forum - BimmerWerkz.com
Old 08-08-2008, 04:01 AM   #1 (permalink)
buffalo zed's Avatar
Car: 1991 318i lux e30
buffalo zed is on a distinguished road
kangaroo fuel
My 1991 318i feels like I have put 'kangaroo fuel' in, especially at low revs. I can still notice the uneven running at increased revs. Is this due to a leak on the fuel line or does the ICV need cleaning, or is it a combination of both.
buffalo zed is offline   Reply With Quote
Old 08-08-2008, 08:52 AM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Lightbulb
ICV controls idle from full closed throttle to about 1/4 throttle, more or less. So, if ur prob occurs at that throttle opening, then yes, ICV fault can be suspected.
Then also, any type of fuel leak will affect performance because a leak suggests that your injectors cannot achieve a correct working pressure.
quality of fuel also plays a role here. stale gas will cause bad engine performance
rough idle probs can also be caused by electrical faults - when was ur last tune-up? plugs, wires, cap & rotor? ... gas & air filters?
*TIP: hesistation at low speed and drives fine at higher speeds-points to failing plug wires
Old 08-09-2008, 01:47 AM   #3 (permalink)
Thanx Darkhorse
I have found a leak on the fuel tank that may be causing low pressure. Looks like taking the tank off and looking at the damage.
Thanx again for your help
no fuel 87325es 3-Series (E21, E30) 3 10-01-2006 03:29 PM
Got fuel? Starmavin 3-Series (E21, E30) 11 04-25-2006 08:11 PM
No Fuel tkb 5-Series (E12,E28, E34, E39, E60) 5 07-03-2005 03:06 AM
Fuel Leaking!!(Fuel tank) chungaa1 1,6,7,8 - Series and Mini Cooper 5 08-10-2004 05:02 PM
fuel Rich328 3-Series (E36) 5 06-20-2004 12:02 PM
