Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 08-27-2003, 01:04 PM   #1 (permalink)
Photos: 0
JUSTIN_325I is an unknown quantity at this point
Send a message via AIM to JUSTIN_325I
My roomate thought he'd give me a hand and hooked up jumpers backwards.. Now when I try to jump it nothing, I mean nothing happens, no dash lights, no nothing.. I am very handy with this thing but I checked fuses, connections, etc... and I cannot get anything to happen!!! Can anyone help??!!!
JUSTIN_325I is offline   Reply With Quote
Old 08-27-2003, 01:06 PM   #2 (permalink)
6th Gear Member
e36_m3_Turbo's Avatar
Photos: 0
i wouldnt doubt that ur electronics are gone now. i dont really have anything to say becuase i never heard of someone doing that. hope everything is ok
No longer red.
Old 08-27-2003, 01:17 PM   #3 (permalink)
Car: E30
Photos: 0
bimmergurl10 is an unknown quantity at this point
Send a message via AIM to bimmergurl10 Send a message via MSN to bimmergurl10
maybe you need to charge your battery, that happens to me all the time. I havent figured out whats wrong with my car though, cuz the battery's only a year old.
<span style='font-size:8pt;line-height:100%'>1987 325iS
</span>
bimmergurl10 is offline   Reply With Quote
Old 08-27-2003, 01:18 PM   #4 (permalink)
6th Gear Member
Photos: 0
u hook up your battery up wrong alot like his friend did?
No longer red.
Old 08-27-2003, 01:38 PM   #5 (permalink)
6th Gear Member
GreenDragon's Avatar
Photos: 0
GreenDragon is an unknown quantity at this point
You blew your alternator. Get it changed. Beat your friend for being a dumbass.
bimmergurl10 - same same, change the alternator. It's not the battery that's gone, the battery just aitn charging correctly because the alternator is shot. Do you have a bumping system in your bimmer?
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 08-27-2003, 01:46 PM   #6 (permalink)
Photos: 0
So you think it is alternator eh?? 87 325i... No bommin system.. yet, needs to run first now!! I am about to have clutch put in when this happened also, just what I need now.. blown alternator.. Are you sure that's it?? You've seen this happen before??
The stink of this whole thing is, I did not tell him to touch anything!!!!!
Old 08-27-2003, 02:05 PM   #7 (permalink)
6th Gear Member
Photos: 0
1) Welcome to the board, I done forgot to welcome you
2) I haven't seen this before, but if you cross the pos and neg on the jump the first thing to go (baring the battery exploding) is going to be your alternator . Unless of course the red was on the neg on his battery and on the neg on your battery, then it wouldn't matter.
3) You could remove the alternator and take it to a shop to be tested, they will tell you for sure if it's blown
4) You could purchase a enw battery and replace yours. If it works then it wasn't the alternator. If it doesn't, return the battery and replace teh alternator.
5) There is also a chance that it's a blow relay and not the alternator, battery, or any fuses.
Old 08-27-2003, 02:16 PM   #8 (permalink)
6th Gear Member
Photos: 0
i'd go with greendragons advice, you couldve also screwed up some other stuff by doing that such as your abs or other electrical stuff.
Old 08-27-2003, 03:10 PM   #9 (permalink)
Photos: 0
Thanks for the welcome aboard! I should have done this a long time ago...
Any Idea which relay would blow if alternator is not bad??
Old 08-27-2003, 03:12 PM   #10 (permalink)
6th Gear Member
Photos: 0
I haven't the slightest clue what relay it would be, sorry. I don't really know much about the e30 models. You may be able to find a wiring diagram (or something of that sort) on the interweb that may help you out though.
Good luck!
Old 08-27-2003, 11:13 PM   #11 (permalink)
Car: E30
Photos: 0
well i found my problem with why my battery kept going dead. My stupid glove box light was staying on, even when it was closed so i disconnected it and hasn't happened since..and i hope it stays that way . And no i didnt hook my battery up wrong. I may be dumb, but i'm not THAT dumb. I know what i'm doing lol
</span>
Old 08-28-2003, 03:08 PM   #12 (permalink)
Photos: 0
Well fella's, All fixed... NOTHING BURNED OUT EITHER.. I removed alternator and had it tested.. Was fine, as a matter of fact, the alternator does not complete the circut. Either way, after that, I went and saw the guy who is doing my clutch for me, he pointed me towards a fusible link in the trunk, hard to find if you dont know it's there... It was fine though, so I started tugging on some wires coming out of the fuse box trying to trace them, and then boom! My wipers kicked on, I had continuity.. Turns out that there is a little junction box on pass side firewall where the positive battery terminates and distributes power.. The shock must have shaken it loose.. Problem solved!!!! Did not even cook my radio... Thanks again for all of your suggestions. We all learned something!! (don't let anyone else touch your car!!!)
Old 08-28-2003, 03:10 PM   #13 (permalink)
6th Gear Member
Photos: 0
Rock on! Glad to hear you didn't fry anything. Did you secure that junction box so it won't losen up again, just in case?
Old 08-28-2003, 03:15 PM   #14 (permalink)
6th Gear Member
lwebb12's Avatar
Car: 2000 M5
Photos: 0
lwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond repute
Send a message via AIM to lwebb12 Send a message via Yahoo to lwebb12
sweet dude.
Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
lwebb12 is offline   Reply With Quote
Old 08-28-2003, 03:17 PM   #15 (permalink)
6th Gear Member
Photos: 0
whoa. that is werid
No longer red.
vB code is On
323i Wouldn't Start TRuckee 3-Series (E46, E90) 8 12-04-2005 02:41 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
