Jack Stands - BMW Forum - BimmerWerkz.com
Old 06-03-2006, 09:22 PM   #1 (permalink)
Neil Paz is on a distinguished road
Jack Stands
So, I jack the rear of the car up today to get this new jack stand in place, but when I went to jack-up the other side the whole thing started to lean.
I know that I'm an idiot because the parking brake is only on the back tires, but how do I go about lifting the back end up if I can't apply the front brakes?
Do I have to raise the front end first on another pair of stands and then put the other two stands in place on the back?
I didn't want to have to put the whole car up on stilts!
At least I got the muffler off with just the one wheel off the ground today.
Any advice from the more mechanically inclined? I don't want to end up getting smushed.:
Neil Paz is offline   Reply With Quote
Old 06-03-2006, 09:52 PM   #2 (permalink)
Car: Opening soon:
There are few hard points that you can use in the rear, the one I prefer is just before the rear tires, you'll see the subframe mount there. Be carefull the gas tank is inches from there. Along the pinch weld about 12" from the front of the rear tire, you'll see a section that has two bolts going into the pinch weld leaving a boxed area. place the jack stand there.
Old 06-04-2006, 12:10 AM   #3 (permalink)
JoeMadoo's Avatar
JoeMadoo is on a distinguished road
Send a message via AIM to JoeMadoo Send a message via MSN to JoeMadoo Send a message via Yahoo to JoeMadoo
I put my floorjack under my differential and place the jack stands on either the rear subframe or where the bmw jack goes where the slots are. Also use a wheel chock for the front tires.
86 Alpine White 335is M30 Swap <br>My Car Domain
ASE L1 Smog Certified
JoeMadoo is offline   Reply With Quote
Old 06-04-2006, 06:37 AM   #4 (permalink)
Red_Rocket's Avatar
Location: Coeur D' Alene, ID : Tuscaloosa, AL : Atlanta, GA
Car: BMW 325
Red_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really nice
Send a message via AIM to Red_Rocket
I jack mine at the same point Starmavin said
Red_Rocket is offline   Reply With Quote
Old 06-04-2006, 09:37 PM   #5 (permalink)
Yep, I was gonna try a wheel chock. Thanks for the advice!
Where Do Jack Stands Go Exactly?? Brian325i 3-Series (E36) 5 10-11-2004 12:55 AM
Supporting car on jack stands scottm 3-Series (E46, E90) 1 05-12-2004 10:59 AM
Jack Stands hartzj 5-Series (E12,E28, E34, E39, E60) 1 10-26-2003 05:46 AM
