is intake on e Hi all
I have a 84 325e that I am changing the intake on, the old one is cracked. I have a intake off of a 87is. The main problem is the power brake vacuum hose. I would like to use the e model throttle body because I don't have the other. Could I tap into the intake side of the idle control valve with a T. Does the alum. intake weld well [cast]. If anyone has struck an arc on one I would like to here from you. The injectors are different to, could I use the "is" injectors? I made a plate for the throttle body, so it fits now. Oh yal long time listener first time caller! Thanks alot. |
