Instrumentation operates intermittently - BMW Forum - BimmerWerkz.com
Old 08-25-2004, 12:32 PM   #1 (permalink)
seandaly is an unknown quantity at this point
Hi all, it's me again!
The tach, mpg, coolant temp, odometer, and fuel gauges operate intermittently in this '86 325 I recently acquired. It's really kinda funny to watch the gauges, because one will drop out for a while, then come back, and then another gauge will drop out and eventually come back. The only gauge that hasn't dropped out yet is the speedo. Sometimes the odometer rolls over, sometimes it doesn't. I guess it needs a rest every once in a while. The fuel gauge works most of the time, but sometimes it just goes *sproing!* straight up, like maybe a pretty woman just passed by, then it settles back down.
Anyway, whenever I get around to looking at it, I'm guessing I should be looking at:
A. Changing the lithium battery
B. Possibly replacing the SI board
C. Check all connections
D. Might need to replace appropriate senders/sensors for gauges
Does this sound about right, or is this one of those "they all do that" problems that you guys know exactly what the answer to it is?
Thanks for you help! (BTW, I'll probably be asking a *LOT* of questions here as I work on this car, hope that's okay! )
seandaly is offline   Reply With Quote
Old 08-25-2004, 02:56 PM   #2 (permalink)
All wheels rolling is an unknown quantity at this point
There are two plugs on the back of the instrument panel. Sometimes the wires in the harness comes loose and you may wnat ot check those out. There are 4 screws that you'll have to undo to get the panel out.
Preston
All wheels rolling is offline   Reply With Quote
Old 08-25-2004, 05:01 PM   #3 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
i agree...mine did this two...it was a combonation of loose connection and litium batterey..check em both...the batterey was a nightmare hah...
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 08-25-2004, 05:24 PM   #4 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
First off... yes.. those are the first things you want to do to hopefully fix the problem.... you hit that on the nail..
Secondly.. we are all here to answer and question each others problems.. Its good to have you...
Les
1997 E36 M3 1990 E30 325i
Old 08-25-2004, 07:06 PM   #5 (permalink)
Thanks for the help guys! I'll check it out soon and report back.
Asc & Eml Lights Come On Intermittently On 99 528i onemoz 5-Series (E12,E28, E34, E39, E60) 4 06-14-2008 10:17 PM
Aircondition Working Intermittently skyrider 3-Series (E46, E90) 3 11-07-2005 07:58 PM
Car lurches intermittently when A/T shifts wango 3-Series (E36) 2 10-31-2005 03:28 PM
Spedometer & Odometer Intermittently quit working osestrada 3-Series (E36) 2 10-13-2005 12:17 PM
Instrumentation All Messed Up! dcsligo 3-Series (E46, E90) 8 04-20-2005 10:26 AM
