Instrument Cluster Wiring - BMW Forum - BimmerWerkz.com
Old 12-22-2004, 02:05 PM   #1 (permalink)
spinkb is an unknown quantity at this point
I am trying to reassemble my dash and instrument cluster after I swapped dashes.
The instrument cluster has three plugs on the back that are large, and color coded as to where they go.
There is also a green plug area that has spots for additional single wires to attach. This is the part I need help with.
I have two wires that have dual female connectors on them. Only one side of the dual connectors has a receptor in it. They each carry 4.5 volts. One has a small label of "1" on it, and the other "2".
Where do these go?
There are three logical slots for them to go into on the back of the cluster (VDO). Does it matter where "1"goes, or "2" goes on these three spots?
What do they do? I randomly tried spots on an old cluster (bad odometer, and bad MPG gauge, . MPG gauge worked and stayed on once the car was warmed up). After doing so, my tach is dead, my MPG is dead(completely dead now), and my SI lights and brake lining lights are on! So on my new cluster I want to be sure before I hook them up wrong.
Can anyone help?
Thanks,
Ben
spinkb is offline   Reply With Quote
Old 12-22-2004, 03:18 PM   #2 (permalink)
idanity's Avatar
idanity is an unknown quantity at this point
sounds like the symptoms of the "obc" batteries going south.
try replaceing the batteries, may save ya some headache
obc=on-board-pooter
member of the <span style='colorrange'>3 pedals club</span>
member of the <span style='colorrange'>195,000+ mile club</span>
<span style='color:red'> its the ones who cant even drive slow that think i cant drive better fast..</span>
idanity is offline   Reply With Quote
Old 12-22-2004, 04:14 PM   #3 (permalink)
I had replaced the SI batteries previously (turned out they were fine, and it was the fuse). This time its not the SI batteries.
I received my new cluster today. It still had the plug for the 4.5 extra wire. It was int he center position, and it was plug #1. I still don't know what to do with plug #2, but at least I know where plug #1 goes.
The new cluster resolves all issues EXCEPT my odometer is still bad. I suspect the guy ripped me off on it though.
He said it was a VDO cluster, 131K miles on it, and all working. What i got was a motometer cluster, 180K miles, and a dead odometer. The speedo works fine, so i suspect the gears are bad on the odo (common issue I believe?)
Any suggestions on fixing the odometer or proving this one is defective?
Thanks,
Ben
Old 12-23-2004, 06:54 AM   #4 (permalink)
OK, my new cluster isn't too bad afterall. The odometer works now. Maybe it just didn't liek the angle of the cluster when I did my first test...don't know.
My main issue now is that I have still one spare wire. It has the number two on it, and I have no idea which plug it should go in. Since it carried 4.5 volts, I don't want to just try plugs and ruin my cluster.
Any suggestions?
Thanks
Old 03-05-2005, 05:37 PM   #5 (permalink)
Tadao is an unknown quantity at this point
Could be the cruise control.
Any suggestions?
Thanks
[snapback]256930[/snapback]
Mark
1984 325e
Tadao is offline   Reply With Quote
Old 03-06-2005, 12:37 AM   #6 (permalink)
wcleafs's Avatar
wcleafs is an unknown quantity at this point
What is the color code on the wire?
it helps when looking at a schematic
oh may of missed the model and year of your bimmer, give me that and I will look at the wiring schematic.
GO LEAFS GO
wcleafs is offline   Reply With Quote
Old 03-06-2005, 08:39 AM   #7 (permalink)
just plug it in, its prolly cruise control. it doesnt matter which one you plug it into
FS: E39,E38,X5 Instrument Cluster Speedometer nit78 Classifieds Sell & Buy 1 09-14-2009 09:19 AM
Instrument Cluster Questions PMB 3-Series (E46, E90) 4 04-20-2005 11:07 AM
Digital Instrument Cluster komodo 3-Series (E36) 5 08-17-2004 05:41 PM
Instrument cluster removal shaman97 3-Series (E21, E30) 5 07-01-2004 03:13 PM
new instrument cluster. hodges 3-Series (E36) 7 05-30-2003 07:49 AM
