Instrument cluster help - BMW Forum - BimmerWerkz.com
Old 10-09-2007, 12:48 PM   #1 (permalink)
triniskunt is on a distinguished road
Smile Instrument cluster help
Hey guys I got an instrument cluster that the whole left side doesn't work, as in the tach and temp guage i believe the other guage at the bottom, i don't know what its called but the one with the needle that keeps moving from left to right depending on how fast you are going and what gear you are in yeah that one...lol Anyway the speedo and the fuel guage work fine and everything on the left side is ok. What could that be, I'm sure that its just my luck that i am the only one to ever encounter that problem. or probably its just something really simple that's just unplugged or some dumb thing like that... oh well any help would be greatly appreciated. Thanks.
triniskunt is offline   Reply With Quote
Old 10-09-2007, 01:04 PM   #2 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
That would be my first guess...there's a few connectors in the back of the cluster....I would say pull the cluster and make sure everything is plugged in....the bently manual has a good "how to" on removing the cluster...you might could find the instructions here using the search feature...
could be a fuse?
yammahamma is offline   Reply With Quote
Old 10-09-2007, 02:10 PM   #3 (permalink)
yeah in one of the other threads there is a link to the removal of the si board which covered the cluster removal. Thanks. you also said that it could be a fuse, are those just the regular fuses in the fuse box under the hood cause my thinking is if it were one of those fuses then wouldn't the whole cluster be out, or are there special fuses for the instrument cluster?
Old 10-09-2007, 04:16 PM   #4 (permalink)
yammahamma's Avatar
Car: '01 330i
I'm not sure...I just read it in another thread as I was searching for how to remove the cluster...
Old 10-09-2007, 05:08 PM   #5 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
The service indicator board or batteries on the board have gone bad. I'm 99% sure a new SI board and batteries will solve your problem with the tach and temp gauge not working. Also, that is the right side of the cluster
My M50 Powered E30 Page
Old 10-09-2007, 11:52 PM   #6 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
hes speaking from the bug on the windshields view...duh
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 10-10-2007, 11:05 PM   #7 (permalink)
Thanks alot guys. Oh yeah sorry I just realized that I did say left BTW How much do those SI boards cost?
Old 10-10-2007, 11:07 PM   #8 (permalink)
One other thing. Does the ABS light come on if your pads are shot?
Old 10-11-2007, 10:55 AM   #9 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
No, either the fuse has gone bad or the ABS relay under the drivers side of the dash has gone bad. There is a separate light for when your brake pads are low.
Old 10-11-2007, 11:01 AM   #10 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
I can get you a brand new one for about $185 shipped anywhere in the continental US.
Old 10-11-2007, 11:09 AM   #11 (permalink)
Thanks do i get anything back for the core? Can I trust any of these guys on ebay for the SI Board? Cause I am watching a brand new rebuilt one for $168 shipped from a2eurotec and an additional $30 for the core.
Oh and yeah the brake lining light is on as well, I was just wondering if they were connected in any way as if one trips off the other or something.
Old 10-11-2007, 11:44 AM   #12 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Once we get your old board back in the orginal box the new one came in you get the $20 core charge credited back to you or we can give you $20 off on your next order. You can see what we sell at Valley Motorwerks - VMWERKS - BMW / Mini Service, Repair, and Parts then click store on the main page.
The brake lining light is on either because the pads are low, one of the sensor wires has been cut/worn through or the soder joint in the cluster has gone bad. All 3 were the cause of my brake lining light being on when I got my white E30 last year, rear pads were worn out, front sensor had been rubbed through from it not being clipped in place right and the soder joint in the cluster was cracked.
Old 10-11-2007, 12:26 PM   #13 (permalink)
yammahamma's Avatar
Car: '01 330i
I swear I got a new SI board for $120 AFTER the core refund...
Old 10-11-2007, 01:03 PM   #14 (permalink)
gotKRAUT's Avatar
well you get a cookie! ^
Kyle Sutherland
1995 BMW 540i/6:
Old 10-11-2007, 03:50 PM   #15 (permalink)
yammahamma's Avatar
Car: '01 330i
I'm not sure if this link will work but here it's listed for $140 but I'm not sure if thats before or after the core refund.
S I board
Changing Instrument Cluster StokeM3Rep 3-Series (E36) 3 06-30-2006 12:58 PM
instrument cluster question funtoos 3-Series (E36) 5 06-02-2006 09:34 AM
Instrument cluster wire Bear 3-Series (E21, E30) 5 03-20-2006 10:42 PM
Instrument Cluster Wiring spinkb 3-Series (E21, E30) 6 03-06-2005 08:39 AM
Instrument cluster removal shaman97 3-Series (E21, E30) 5 07-01-2004 03:13 PM
