Instrment cluster indicator light - BMW Forum - BimmerWerkz.com
Old 01-25-2006, 01:20 PM   #1 (permalink)
1990 E30 Cabriolet and the left turn signal indicator light in instrument cluster is inoperative. I changed the bulb and even switched out a good bulb and holder but she no workee. The signal lights work and the flasher relay clicks, as well as the right signal indicator. Do I have a bad cluster connection and do I need to take the back off of the cluster and resolder the wiring to the inop bulb?
bear
Old 01-30-2006, 01:00 AM   #2 (permalink)
fporro is an unknown quantity at this point
Send a message via MSN to fporro Send a message via Yahoo to fporro
bear
Uhm,
i never seen a bad Mother Board and not sure if the Service Indicator board has anything to do with it's operation., perhaps there's a bad soldering point somewhere.
cheers,
Frank
e30 parts
fporro is offline   Reply With Quote
Old 01-30-2006, 01:29 PM   #3 (permalink)
IP Cluster
I am going to pull the cluser, separate back from front and clean and reflow the printed circuit to the indicator light. Since all exterior lights as well as all other indicators and the flasher I am assuming a break in printed circuit.
Old 01-30-2006, 10:35 PM   #4 (permalink)
Car: Opening soon:
I have seen where repeat removal can wear the contacts away. But mostly they just get dirty.
Old 01-31-2006, 02:00 PM   #5 (permalink)
IC issues
This will be the first time out so I will look at all circuits and clean or repair as necessary.
E39 Instrument Cluster replacement mileage questions BaksTab 5-Series (E12,E28, E34, E39, E60) 9 10-20-2007 04:06 AM
Instrument Cluster Wiring spinkb 3-Series (E21, E30) 6 03-06-2005 08:39 AM
Instrument cluster removal shaman97 3-Series (E21, E30) 5 07-01-2004 03:13 PM
new instrument cluster. hodges 3-Series (E36) 7 05-30-2003 07:49 AM
