Insp Light Problem - BMW Forum - BimmerWerkz.com
Old 12-13-2005, 02:15 PM   #1 (permalink)
Gabrielpr12 is an unknown quantity at this point
Send a message via MSN to Gabrielpr12 Send a message via Yahoo to Gabrielpr12
Insp Light Problem
Hello Everyone, I Know this topic has come up way too many times, but I just want to make sure I understand what my problem is. My inspection light came on, but this time it has the yellow and the red lights on, I tried reseting it but it wouldn't work. Does this mean that mi SI board or batteries are bad? Also the car does a beep sometimes when I am driving. Please let me know. Thanks in advance.
BMW newbie.
Gabrielpr12 is offline   Reply With Quote
Old 12-13-2005, 02:33 PM   #2 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
The beep could mean that the outside temp has gone below 36 degrees. 36 will then appear on the OBC.....that allways threw me off when I first got my car.
yammahamma is offline   Reply With Quote
Old 12-13-2005, 07:03 PM   #3 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
start with the batteries.
My BMW Blog
Old 12-14-2005, 11:11 AM   #4 (permalink)
Yep, the temp has been below or around 36 degrees. I will attempt to check the batteries, since I thinks that's the least expensive part.
BMW newbie.
Old 12-14-2005, 02:28 PM   #5 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Word, part number 23-191 from your local radio shack. Then just solder them onto your board.
My BMW Blog
Old 12-14-2005, 04:06 PM   #6 (permalink)
Red_Rocket's Avatar
Location: Coeur D' Alene, ID : Tuscaloosa, AL : Atlanta, GA
Car: BMW 325
Red_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really nice
Send a message via AIM to Red_Rocket
the beep could also mean that the memo button is enabled on your clock, check to see if it says ME in the corner on the clock display
Red_Rocket is offline   Reply With Quote
Old 12-17-2005, 10:59 PM   #7 (permalink)
Car: Opening soon:
If you have the stock raido, it will beep when it thinks it needs cleaning. Changing the batteries in the cluster can turn and bite you in rear, there are 2 different types batteries, some are the same size of 2 aa others are weird sized looks like a half of aa, 3V batteries that are hard to get and are costly.
Old 12-17-2005, 11:56 PM   #8 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
But it has to be cheaper than actually buying a new SI board...
My BMW Blog
Old 12-18-2005, 10:46 PM   #9 (permalink)
Car: Opening soon:
Don't rule out buying a new board, 7 times out of 10 the batteries leaked out acid and killed it anyway.
Old 12-24-2005, 05:02 PM   #10 (permalink)
Thanks for the advice, I really have to check my batteries, but it's too cold to work on my car right now. I will let you guys know the status.
BMW newbie.
Light Trouble, Power Trouble PariaH 5-Series (E12,E28, E34, E39, E60) 1 05-06-2005 02:27 AM
Can Fix My Air Pump Problem, Check Engine Light Esme 3-Series (E36) 1 05-05-2005 12:33 AM
Check Engine Light On, But Only When I Start Car BMW-ATI 3-Series (E36) 5 04-15-2005 09:40 PM
Abs/asc Light On 2000 523/525 Avatar1 5-Series (E12,E28, E34, E39, E60) 2 10-16-2004 08:49 AM
330CI LED Tail light conversion problem kwoktoa 3-Series (E46, E90) 2 02-05-2004 07:47 AM
