injection cleaning, 85 318i - BMW Forum - BimmerWerkz.com
Old 07-26-2010, 02:04 PM   #1 (permalink)
divot61's Avatar
divot61 is on a distinguished road
has anyone had any luck removing a plastic injector and taking it apart, if its possible?, and cleaning it out? #3 cyl will not fire, dry plug, removed the plug wire and still ran crappy, no change in idle, still rough and no power, once in a while it will kick in and run like it should but mostly it misses and runs cruddy. tanks guys for any input
divot61 is offline   Reply With Quote
Old 08-11-2010, 03:58 PM   #2 (permalink)
OldChevelle is on a distinguished road
There are places that clean and rebuild injectors, RC Engineering is one that comes to mind: Fuel Injector Cleaning
OldChevelle is offline   Reply With Quote
Old 08-13-2010, 03:57 AM   #3 (permalink)
learoy E30 is on a distinguished road
Thumbs up Injector issue
Hi, if you sure its the injector at fault try getting swapping it with one of your other injectors or possibly try gettin a second hand replacement,this is all just in case your problem lies elsewhere. so you dont fork out for a problem that doesn't exist.
learoy E30 is offline   Reply With Quote
Old 08-23-2010, 10:17 PM   #4 (permalink)
Car: 1990 BMW 735iL
beamers4life is on a distinguished road
Check out autohausaz.com. They will have an original oem injector made by bosch for it for like 80 dollars and free shipping.I wouldnt get an aftermarket in case it operated somewhat different than the other OEMs. If you did that id get 6 extra seals. (2 per injector for the other 3 injectors) and put them on. most of the time the injector fails due to that seal dry rotting and going bad over time. It did it on my e32 3.5 motor. IN my mind i think 80 bucks is cheaper than even messing with them.
beamers4life is offline   Reply With Quote
Fuel Injection Problem? bmw325es 3-Series (E36) 3 01-26-2005 11:05 PM
New Fuel Injection Kits hcar M-Series (M1, M3, M5, M6) 0 03-15-2004 12:56 PM
New Fuel Injection KIts hcar 3-Series (E36) 0 03-15-2004 12:55 PM
New Fuel Injection Kits hcar 3-Series (E21, E30) 0 03-15-2004 12:54 PM
Fuel Injection Kit hcar 3-Series (E36) 0 03-12-2004 01:07 PM
