ignition key wont turn past stop 1 - BMW Forum - BimmerWerkz.com
Old 08-12-2004, 12:25 PM   #1 (permalink)
freddie is an unknown quantity at this point
Hi all,
my 1988 325i's ignition key will not rotate the barrel past the first stop point. i can get power for the radio but it will go no further.
i am assuming the problem is with the actual key barrel as i have tried using both keys. i have sprayed light oil down it to try and free things up a little but nothing as yet.
the steering lock is not the problem and i have stripped the trim down in an attempt to get a better view.
has anyone had any experience removing the key barrel itself for replacement. that thing is well and truly stuck in there.
does anyone have any other ideas?
freddie is offline   Reply With Quote
Old 08-12-2004, 03:56 PM   #2 (permalink)
FizzNakLe is an unknown quantity at this point
turn the wheel slightly and turn the key... it's a common problem with all cars, when the steering column locks it messes it up a little.
so a small turn on the steering wheel and then turn the key
nevermind... I just re-read your post....
FizzNakLe is offline   Reply With Quote
Old 08-12-2004, 04:49 PM   #3 (permalink)
BMW Lover's Avatar
BMW Lover is an unknown quantity at this point
Send a message via AIM to BMW Lover
hm...do you know the history of the car? how long hav u had it and when did this start actually happening?
^^I want this where I live.
"Drag racing a BMW is like going fishing with a hooker, it's fun but it's not what you got her for..." - M3DUDE
Manual - The transmission hated by moms/wives/girlfriends everywhere...
Member of the "I Owned my Bimmer when I was 17" Club
Member of the "10 Year Old" Club
Member of the "3 Pedal" Club
Member of the "3 Light" Club
BMW Lover is offline   Reply With Quote
Old 08-13-2004, 06:01 AM   #4 (permalink)
it's been a good car with only minor glitches in the past. had it around 6 years now.
it started last week in hot weather. i thought the heat may be effecting it so left it to cool off but it never recovered.
i'm sure these things do wear out as they are mechanical parts, just it seems a real bugger to change.
if i could get the thing out in one piece i may be able to take a look at it, but i still have no idea how to remove the barrel without destroying it.
has anyone had one out before, not necessarily out of a 325, but just as a pointer as what to do next?
Old 08-13-2004, 08:33 PM   #5 (permalink)
BMW Lover's Avatar
damn...hmm obviously its frozen...hmm im tryin to think of anything :-/ nothing comes to mind...i think ur gona need to take it to a mechanic
Old 08-13-2004, 09:49 PM   #6 (permalink)
johnny-b is an unknown quantity at this point
Hey man,
I had the exact same prob on my 88. Mine would only stop working when it was cold out. I took it to a lock smith and he said it is because german car manufacturers use a grease in their locks that is too thick for its own good. It works well for the lock but if it gets too dirty it gets so stiff (especially when cold) it stops functioning well. He said get some lock de-icer or some thing else alcohol based and spray it in the tumbler until the pin moves freely again. Not sure if it helps but its alot cheaper than a mechanic. By the way $1.95 later and mine has worked ever since. Good Luck!!!!!!! P.S. the whole steering column has to come out for the tumbler or so i have been told.
johnny-b is offline   Reply With Quote
Old 08-14-2004, 11:50 AM   #7 (permalink)
thanks guys, i'll give your suggestion a go johnny-b. if not it looks like an expensive replacement plus 3-4 weeks for a key match
Old 08-14-2004, 08:45 PM   #8 (permalink)
Speedy-325is's Avatar
to remove the tumbler, put the key in and turn it to position 1
take a piece of wire maybe 20gauge
find a hole on the tumbler just to the right of the key
push the wire in and depress the button thet locks the tumbler(barrel) in the column
keeping button depressed, pull out the tumbler
hope this helps, or you can also order new tumbler with 2 keys, factory made. i purchased mine for about $70. do not buy it from the dealer though unless you have loads of $$$. find it online, not too hard.
no need for a mechanic, and a good locksmith may be able to pop out a key in a few minutes if yours are not lazer cut.
Mark
Old 08-15-2004, 10:40 AM   #9 (permalink)
cheers speedy, i've got the idea of how to get it out but need something stronger than wire. i can push it in so far but it just bends after that.
i'll try something like a bicycle spoke and see what that does.
i'm going to soak it in wd40 for while and see what comes out. hopefully that should sort it.
key won't turn all the way?! booger 3-Series (E36) 1 10-29-2005 07:46 AM
Change temp display? mdimbler 5-Series (E12,E28, E34, E39, E60) 1 10-23-2005 11:58 PM
Need Help (ignition Key Locked) stalliondz 5-Series (E12,E28, E34, E39, E60) 8 08-26-2005 05:09 PM
Can't turn key past first stop maricl 3-Series (E21, E30) 2 06-28-2004 11:40 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
