Idling issue - BMW Forum - BimmerWerkz.com
Old 05-07-2003, 09:16 AM   #1 (permalink)
bostonsports is an unknown quantity at this point
Hi,
Need help. I have a 1988 bmw 325 ic and the car idles when warm from 750 rpm to 3500 rpm. The timing belt was replaced, fuel injectors are new, and the air flow sensor has tested ok.
Any suggestions?
Bostonsports
bostonsports is offline   Reply With Quote
Old 05-08-2003, 08:50 AM   #2 (permalink)
Fox
Moderator
Send a message via ICQ to Fox Send a message via AIM to Fox Send a message via MSN to Fox
Yea, its the ICV or idle control Valve. Spray some WD40 up in there and that should solve the problem if not just temporarily. ill get pics of where it is if you cant find it
Fox is offline   Reply With Quote
Old 05-10-2003, 12:36 AM   #3 (permalink)
87 325 is an unknown quantity at this point
Where is the ICV located? I've had a similar issue, but not as drastic. Idle jumps around from 750 to 1000 or so. The new exhuast I just got added helped a bit, but I'd still like it to be smoother. Pics would really help a lot, Fox. Thanks
87 325 is offline   Reply With Quote
Old 06-12-2003, 05:46 AM   #4 (permalink)
ex owner/admin
Furious's Avatar
check the FAQ forum. there is a general FAQ on this issue.
Old 09-25-2003, 06:59 PM   #5 (permalink)
Disco E30 is an unknown quantity at this point
I have had ideling trouble on my e30 325i touring. That was a small split in the air intake hose from the air cleaner to the idle control valve
Disco E30 is offline   Reply With Quote
Old 09-26-2003, 08:42 PM   #6 (permalink)
alanh's Avatar
alanh is an unknown quantity at this point
Send a message via AIM to alanh
i have the same problem
Self-Proclaimed Genius
alanh is offline   Reply With Quote
Old 09-28-2003, 02:43 PM   #7 (permalink)
On my 325i the idle control valve is located on a pipe comming off the air intake. If you follow the air intake pipe from the air filter box, you will find a small pipe comminig off before you get to the throttle body. The small pipe goes into a metal 'tube', and then I think the pipe out of the other end goes back into the main engine air-intake bu the other side of the throttle neck. You will see an electrical conector atatched to the side of it as well. My car is a UK spec 325, not sure if that makes a diffrence.
I have been told you can clean them up with brake cleaning fluid. I just got a new one from the scrap yard, then found it was the a split in the airintake pipe.
When the engine is running the idle speed should increase if you remove the electrical contacts, and the resistance should be 9 - 10 ohms at about 73 degrees F, (23 degrees C)
Hope that helps
Kind regards
Dave
Old 09-28-2003, 03:20 PM   #8 (permalink)
I know some 318 (i think late 1985 models) have an idle stabalization relay. Thats also worth a look as I have had a couple of engine management problems that have always been traced back to certain relays.
Old 09-29-2003, 01:25 AM   #9 (permalink)
BmWNoobie is an unknown quantity at this point
i have the same problem the car goes revin itself and idles... what happen to my is the air filter boot or hose .. i got a new one and it works pretti good not but best is to change the air filter too... thats my opinion im not shure but try it out esp to the ppl wit the cut on teh air filter hose. 1986 bmw 325e
BmWNoobie is offline   Reply With Quote
Old 10-03-2003, 09:27 PM   #10 (permalink)
JUSTIN_325I is an unknown quantity at this point
Send a message via AIM to JUSTIN_325I
I have the same problem with my 87 325i... I also heard that there is another sensor/switch that goes hand and hand with the ICV. It is located underneath the dash somewhere.... Does anyone know anything about this? I heard it from a very reputable source. Who knows...
JUSTIN_325I is offline   Reply With Quote
Old 10-24-2003, 11:07 AM   #11 (permalink)
CNLiberal is an unknown quantity at this point
I also have the same problem on my '91 318is. However, it is not a constant thing. It happens if I do a cold start SOMETIMES. I do alot of driving in a day (usually 60 miles) and it happens sometimes when I come to a stop after being on the highways for 30 minutes. That leads me to believe that it is something else besides a crack somewhere. Is this incorrect?
CNLiberal is offline   Reply With Quote
Clutch Issue? pamato 5-Series (E12,E28, E34, E39, E60) 9 10-27-2005 03:32 PM
Unstable Idling On 'd' 94 325is wango 3-Series (E36) 6 09-01-2005 02:42 AM
Any Issue For Putting Obd I M3 Engine In 325i? r6bruin 3-Series (E36) 2 08-13-2005 07:12 AM
Shorting in a fuse for guages, and other idling. M5power 5-Series (E12,E28, E34, E39, E60) 0 04-10-2004 11:35 PM
Idling issue bostonsports 3-Series (E21, E30) 5 05-09-2003 11:05 PM
