Idle problems - BMW Forum - BimmerWerkz.com
Old 04-12-2007, 06:32 PM   #1 (permalink)
BADD E39 WAGON has a spectacular aura aboutBADD E39 WAGON has a spectacular aura aboutBADD E39 WAGON has a spectacular aura about
Idle problems
Check engine light come on at idle
BADD E39 WAGON is offline   Reply With Quote
Old 04-14-2007, 10:27 AM   #2 (permalink)
photoguy30523's Avatar
photoguy30523 is on a distinguished road
u know i am having the same problem, but when i accelerated it goes away...just on idel that it comes on
photoguy30523 is offline   Reply With Quote
Old 04-14-2007, 04:32 PM   #3 (permalink)
MEDSTUDENT87's Avatar
Car: '90 525i
MEDSTUDENT87 is on a distinguished road
Send a message via AIM to MEDSTUDENT87
Sounds like the MAF. My car did that and that is what it was.
MEDSTUDENT87 is offline   Reply With Quote
Old 04-15-2007, 12:01 AM   #4 (permalink)
Car: Opening soon:
Y.M.M. (Year make model)
Old 04-15-2007, 12:32 PM   #5 (permalink)
90
I have a 1990 325
Old 04-15-2007, 11:01 PM   #6 (permalink)
Car: Opening soon:
Auto or stick?
Old 04-16-2007, 12:11 AM   #7 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
no E30s came with a MAF, but they did come with an AFM
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 04-16-2007, 06:01 PM   #8 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Odd. I thought the two terms were interchangeable. What's the difference?
Old 04-17-2007, 12:11 AM   #9 (permalink)
gotKRAUT's Avatar
AFM is an Air Flow Meter, its basically a trap door that opens as air is pulled through thus chaging the measurement for fuel adjustment
MAF is a Mass Air Flow unit... usually a "Hot Wire" which measures by the air esentially cooling the wire and getting its measurement from that resistance/change in frequency....
Kyle Sutherland
1995 BMW 540i/6:
Old 04-17-2007, 09:17 PM   #10 (permalink)
Car: Opening soon:
Yeah, what he said.
Old 04-17-2007, 09:32 PM   #11 (permalink)
Originally Posted by Starmavin
Yeah, what he said.
we still havent got any answer or ideas
Old 04-17-2007, 11:40 PM   #12 (permalink)
gotKRAUT's Avatar
well what have you been testing all this time? lol...shesh...
Kyle Sutherland
1995 BMW 540i/6:
Old 04-18-2007, 06:40 AM   #13 (permalink)
Car: Opening soon:
If you can stall the car with out turning the key off, then do a code retrieval. If this doesn't produce any codes, you'll need a code scanner. With out a code to go by who knows what the computer is trying to say, and you can't very well diagnose a check engine light with out one.
Old 04-18-2007, 06:55 PM   #14 (permalink)
1222
Old 04-19-2007, 12:29 AM   #15 (permalink)
Car: Opening soon:
You both are getting the same code 1222?
I'll repost what 1222 is again, if there are any other codes. Let me know:
1222 is stored when the DME detects excessive deviations in the air-fuel mixture (too rich and too lean) for longer than 10 seconds.
Possible causes: Faulty O2 sensor or bad contacts to O2, fuel tank ran empty or very low, injectors bad or clogged, incorrect fuel pressure (clogged fuel filter, bad regulator, faulty fuel pump), engine temperature sensor bad, intake or exhaust leak, fuel evap control bad or broken vac lines, air flow meter defective and/or the combustion is being messed up by mechanical failure (worn out spark plugs, low compression, intake/exhaust valves, bad plugs, wires, cap rotor, etc)
Here are other DME codes:
1211 DME control unit.
1215 Air flow meter.
1216 Throttle Potentiometer.
1221 Oxygen sensor.
1222 Oxygen sensor control range limit.
1223 Coolant temperature.
1224 Intake air temperature sensor.
1231 Battery voltage.
1232 Idle switch.
1233 Full load switch.
1251 Fuel injector valves cyl. 1+3+5.
1252 Fuel Injector valves cyl. 2+4+6.
1261 Electrical fuel pump circuit.
1263 Idle control valve.
1264 Oxygen sensor heating.
1444 No failures.
740i/M62/Auto (1997) - Engine Idle and ASC problems BigBazza 1,6,7,8 - Series and Mini Cooper 0 01-19-2006 04:19 PM
Idle Problems BeelZibub 5-Series (E12,E28, E34, E39, E60) 10 07-10-2005 04:56 AM
Idle Problems, Intake Service Bulletin? rhansen162 5-Series (E12,E28, E34, E39, E60) 1 03-06-2005 07:18 PM
