IDLE PROBLEMS! - BMW Forum - BimmerWerkz.com
Old 06-05-2004, 11:31 AM   #1 (permalink)
dfw325e is an unknown quantity at this point
Okay here's the deal. I just finished putting a new clutch in my 85' 325e, and now my idle has been funny. For days it will run PERFECT, then all of a sudden the idle fluctuates and it wont stay running..then it just goes away and runs good again. Checked fuel lines, vacuum leaks, has new fuel filter, new plugs, and clean air system. Is there a vacume line under the car i cant see? Or is it a sensor? Can it be O2 sensor?
Please help this is driving me crazy..
dfw325e is offline   Reply With Quote
Old 06-06-2004, 11:58 AM   #2 (permalink)
CiscoKid's Avatar
new oil?
Old 06-06-2004, 09:29 PM   #3 (permalink)
alanh's Avatar
alanh is an unknown quantity at this point
Send a message via AIM to alanh
could be your comp
Self-Proclaimed Genius
alanh is offline   Reply With Quote
Old 06-07-2004, 01:41 AM   #4 (permalink)
detour54 is an unknown quantity at this point
Send a message via AIM to detour54
Your bad O2 sensor would make your car run funny, but I don't think it would make it stop running.
If I were to guess, I would say it sounds to me like you might have a vacuum leak, but you said you have already checked that.
<a href='http://www.e30tech.com/forum/viewtopic.php?t=8854' target='_blank'><img src='http://www.e30tech.com/pictures/e30/sig25.jpg' border='0' alt='user posted image' /></a>
detour54 is offline   Reply With Quote
Old 06-07-2004, 10:51 PM   #5 (permalink)
Car: Opening soon:
Idle air control motor could be sticking try cleaning it out, also clean out your throtle body with a rag and carb cleaner, just hold open the throtle and spray and wipe both the bore and valve. You wouldn't belive what a difference it'll make alone. (be carfull not to let the valve close on your finger, it will hurt) Also, check for tears in your intake boot.
Good luck.
Old 06-08-2004, 02:50 AM   #6 (permalink)
rmxpete is an unknown quantity at this point
I also had the same problem with my E30 I just done what "Starmavin" said to do and it ideld fine afterwards,I l8ter sold it and Brought a 328is the other day!!
rmxpete is offline   Reply With Quote
Old 06-10-2004, 05:26 PM   #7 (permalink)
Hey, thanks for all the feedback...i will definitly try cleaning the items recomended. How should i go about cleaning the Idle air control motor? Im starting to think it is just a clogged system full of carb deposits.
Thanks again for all the feedback..I sure appreciate it!
Old 06-16-2004, 12:55 PM   #8 (permalink)
Hammer is an unknown quantity at this point
You might also want to check out the idle control valve.
Hammer is offline   Reply With Quote
Old 07-31-2004, 09:49 PM   #9 (permalink)
69th Gear Member
BeachBunny's Avatar
Car: 1996 328IS
BeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond repute
ditto
BeachBunny is offline   Reply With Quote
Old 01-13-2005, 09:38 PM   #10 (permalink)
infotron is an unknown quantity at this point
did you ever sort out your problem as I have exactly the same issue.
infotron is offline   Reply With Quote
Old 01-18-2005, 06:50 PM   #11 (permalink)
Kowalski's Avatar
[snapback]271135[/snapback]
check your fuel pressure, could be dropping off every once in a while do to a bad connection, or the idler valve has a bad conection, use a volt meter and check both, or you might need a new fuel pump.
264* roatation and 388 lift
Old 01-19-2005, 01:01 PM   #12 (permalink)
Red_Rocket's Avatar
Location: Coeur D' Alene, ID : Tuscaloosa, AL : Atlanta, GA
Car: BMW 325
Red_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really nice
Send a message via AIM to Red_Rocket
Yea mine idles funny on start and reverse, i have to give it some gas to get it up to the right RPM and then it goes fine?
Red_Rocket is offline   Reply With Quote
Old 01-19-2005, 01:05 PM   #13 (permalink)
Kowalski's Avatar
[snapback]274875[/snapback]
sounds like the same problem i have, it sounds like a vacume leake, i have one and im gona get arround to fixing it soon, i still have to fix my fuel millage guage too, but yeah mine does that too, idles a little rough constantly but i can hear the leak, im gona get all new rubber hoseing, i figure 14 years and its time for new hoses... so yeah, try that, and if that doesn't fix it its fuel related
E36 320 M50tu Lumpy Idle finite 3-Series (E36) 4 11-17-2008 03:47 PM
Idle Problems BeelZibub 5-Series (E12,E28, E34, E39, E60) 10 07-10-2005 04:56 AM
Warmed up idle puzzle. nightsurfride 3-Series (E21, E30) 2 02-03-2004 08:04 PM
