Idle Control Valve - BMW Forum - BimmerWerkz.com
Old 04-12-2009, 04:15 PM   #1 (permalink)
E30 320I is on a distinguished road
Idle Control Valve
Hi, Could Anyone Advise Me How You Can Tell If Your Idle Control Valve Has Gone?
I Have Cleaned My Idle Control Valve And It Started To Make A Noise Like Something Was Moving Inside, Is This Normal?
My Car Started To Run Better, But Still Not Quite There
E30 320I is offline   Reply With Quote
Old 04-12-2009, 08:27 PM   #2 (permalink)
PrInG's Avatar
Car: 95 Dakar Yellow M3, 00 1.8T VW GTI
PrInG has a spectacular aura aboutPrInG has a spectacular aura about
Send a message via AIM to PrInG
if the idle control valve is not working correctly your car is gonna have a terrible idle.. your probably wont be able to keep it running. Most likely at least. Mine was dirty a couple times and the car would rev way up and then just shut off. Also when you rev the car it hesitates to come back down... hope this helps a little bit.. Mine never made any strange noises..
TO HONOR: Get Honor Stay Honor if You Can't Come in Her Come Honor.
"its not banana yellow but its not golden its just that perfect creamy german goodness"
- Bow
PrInG is offline   Reply With Quote
Old 04-12-2009, 08:53 PM   #3 (permalink)
mtccl's Avatar
Car: It's silver
mtccl is on a distinguished road
Idle will be normal on cold start and then too high (about 1500 rpm) once car has warmed to normal operating temp if the ICV is bad. Other indication is that the idle will surge or hunt after normal warm up. ICV is not active during cold start.
2002 BMW 330XI
1988 Porsche 944
mtccl is offline   Reply With Quote
Old 04-13-2009, 07:35 PM   #4 (permalink)
yeah, 'hunting' for idle is a classic symptom. from 300 to 1700 at will....doesn't quite know what he wants to do.....but he's fine when under load...just that pesky idle....
silversled is offline   Reply With Quote
Idle Control Valve Bunny Capricorn 3-Series (E21, E30) 2 08-10-2005 03:37 PM
Idle Control Valve Gomerino 3-Series (E21, E30) 5 03-01-2005 02:19 AM
Idle Control Valve? Xx1Lethl50xX 3-Series (E36) 3 11-19-2004 03:11 PM
02 Sensor/idle Control Valve bmw 318i se 3-Series (E46, E90) 0 10-10-2004 04:10 PM
Idle Control Valve Help Robdrmer1016 3-Series (E36) 7 07-16-2004 02:15 PM
