__________________ Kyle Sutherland
1995 BMW 540i/6: The Calypso Beast Vid 0-70ish 1987 BMW 325es: Face & Butt Lifted/M50tu Swapped*Sold* 1985 VW Scirocco: Too many mods, money pit*Sold* E34 Plate Filler Wanted!
The things that come to my mind are, bad main realy, bad DME, AFM has been messed with and is not adjusted properly, dead AFM, not seeing a crank/ignition signal, bad engine temp sensor (different than the sensor that sends the signal to your gauge in the cluster), very little or no gas in the tank.
When did the not starting problem first start? Did you change some parts or mess with anything right before this problem happened? Was the car sitting for a long time? Did the car run rough then not want to restart?
The main thing 90% of people forget when trying to work on their own car is start simple and don't just throw parts at it. If most people would add up the $$$ they spent on parts that didn't fix the issue before they took it into our shop it would more than cover the diag time we spent figuring out their BMW. I see it all the time at the shop I work at. Its usually some guy that is too proud to have a shop work on his wife's/GF's car that ends up bring it in for us to fix cause the hundreds of dollars in parts he threw at it didn't fix it. And very rarely does the parts they replaced help the problem get better.
As half said earlier you need three thing fuel spark compression actually test them put a screwdriver or an old plug into a lead put it close to a good earth and crank it, crank it and then pull a plug you should smell fuel if not pull the injectors and rail out re-connect it and crank it see if they spray (don’t blow yourself up) with the plug in you can normally hear compression but if not test it compression testers are cheap enough 10-12bar. Then when you know which ones missing you can start to find out why
