| Test the fuel pump first. Pull out the rear seat and there should be an access panel to get to the fuel pump. Please don't smoke while playing near the gas tank. See if there is power at the pump. I have seem a fuel filter get clogged by sediment in the tank when it is run dry but this is rare, if you haven't changed the filter in a while now might be a good time to change it as a bit of preventive maintinance.
Ben
__________________ "It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife. |
