i come begging for help overheating - BMW Forum - BimmerWerkz.com
Old 05-10-2008, 05:52 PM   #1 (permalink)
jpwmotorsport is on a distinguished road
Cool i come begging for help overheating
hello all new to this forum not to bmw!!!
first things first :e30 1988 m20 320I cab uk RHD..
only just bought today of a friends brother on the cheap been driving jap stuff for a while {holds head in shame} used to have e34 and e32 but both were multi-valve so dont know much about m20 and such ...
my problem is..... overheating at stand still been through usual stuff like thermostat, air in system, compression test, but still the poor baby overheats at standstill.... was thinking fan could be issue as i am right in thinking its a viscous coupling like a m40 can anyone offer a helping hand to a man returning to the bmw fold
jpwmotorsport is offline   Reply With Quote
Old 05-10-2008, 07:07 PM   #2 (permalink)
I think it is the fan clutch, I went through the same issue with the M20 2.5
Old 05-20-2008, 10:42 PM   #3 (permalink)
Car: 85 325e 90 525I '96 328i
pinnaclebass is on a distinguished road
Send a message via AIM to pinnaclebass Send a message via Yahoo to pinnaclebass
ya if its a hot day and ac is on at standstill, the engine temp may go past the middle. most likely because of fan clutch. have you noticed a change in power while driving?
pinnaclebass is offline   Reply With Quote
Old 05-21-2008, 01:27 AM   #4 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
does it over heat at highway speed? if not fan clutch
you should hear the fan spin up when the car starts getting hot
1992 318i Coupe parts car
I am Captain Obvious
Old 05-21-2008, 08:29 PM   #5 (permalink)
DIRTE30's Avatar
DIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond repute
Send a message via Yahoo to DIRTE30
Definitly a fan clutch... just visit your local junk yard and find one that feels good. They ain't real cheap otherwise!
DIRTE30 is offline   Reply With Quote
Old 05-26-2008, 10:29 PM   #6 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
while i will not rule out the fan clutch as culprit; your prob sounds more like a partially clogged radiator to me. Logic being that if u have airflow (when u are not at at standstill) you are fine... fan speed at idle or at speed is more or less a constant depending on the viscosity of the internal fluid.
My way would be to turn on the A/C at idle(for added load) and watch temp. If temp rises faster that it otherwise would with the A/C off, then it is radiator ;-) if not difference... then fan clutch
E 46 overheating ... again. TRuckee 3-Series (E46, E90) 7 06-09-2007 12:44 PM
Overheating DeathMetal 3-Series (E21, E30) 14 07-16-2005 01:26 PM
Overheating. Brian325i 3-Series (E36) 3 11-02-2004 02:44 PM
Overheating StevO 3-Series (E36) 4 09-07-2004 04:52 AM
my problem part 2 .. begging for help p3rsian 3-Series (E36) 7 07-21-2004 02:14 PM
