Hydrulic Brake Line ? - BMW Forum - BimmerWerkz.com
Old 09-03-2010, 08:32 PM   #1 (permalink)
87BeemerBoi is on a distinguished road
Gota 87 E30 325i and changed the rotors and pads and bled the lines, but then went fora drive and had no pressure to the brakes, so checkem them again, and still no pressure. jacked the car up and pumped the brakes, and the brake fluid was spraying like a cut artery from one of these 3 lines running underneth the car. i dont have a picture, and couldnt find a picture. but was told it wasthe main hydrulic brake line... is that a custom part or is that a dealer only fix, or what would i use to replace that?
87BeemerBoi is offline   Reply With Quote
Old 09-06-2010, 02:37 PM   #2 (permalink)
not even a possable guess?
Old 09-14-2010, 08:50 PM   #3 (permalink)
Originally Posted by eastburn84 View Post
I belive you are talking ablout the main steel brake lines and in that case there are 2 ways to fix it.
Bend a new line to fit, Costly and time consuming.
you will need a line bender and a flare kit.
The less correct way is to cut out the bad section and tap in a new piece of line using cuplings. either way your local parts store should have theese items. Check pep boys we just did this for a customer last week. Road Salt is a bitch.
thank you very much !
Brake Pads & Message Line SUPER_SPORT 5-Series (E12,E28, E34, E39, E60) 1 05-30-2010 11:03 PM
Brake Line &abs Lights NBIMPORTS 3-Series (E36) 1 02-13-2007 12:16 PM
Anybody know a good trick to get at that stupid brake line? triggrhaapi 3-Series (E21, E30) 5 10-17-2006 12:12 AM
325ix Brake Line From Abs altered 3-Series (E21, E30) 0 07-17-2005 11:02 AM
brake lining line nelson 3-Series (E21, E30) 12 06-08-2004 02:01 PM
