Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 05-03-2004, 05:37 PM   #1 (permalink)
Photos: 0
drwambo is an unknown quantity at this point
Ok, I may have asked this before, but I'm at my wits end.
Car was idling high (around 1100-1200) decided that maybe the ICV was dirty. Pulled it off and cleaned a bunch of crud out, and reinstalled. Now the car will idle up to about 1500 then drop down to around 800 then back up again.
I've attempted to set the idle with the screw on the ICV and found that the faster I set the idle, the faster it cycles up and down.
I've sprayed carb cleaner over every hose I can find, as well as the intake manifold, and can find no vacuum leaks. My only other thought was the O2 sensor, but would that cause a regularly pulsing idle? Do I need a new ICV? I've set the idle screw all the way down to the stop, and it still seems to be idling high.
Any other thoughts? This is driving me nuts!!
THanks,
Douglas
drwambo is offline   Reply With Quote
Old 05-03-2004, 09:32 PM   #2 (permalink)
Photos: 0
Ok, I can help to fix your issue.
The problem you are seeing will be resolved when the weather gets warmer and the fuel mixture returns to a summer mixture.
To correct it faster you need to insert a restricter in the intake side of the ICV.
Any restrictor with a 1/4 inch hole will work.
I use a rubber sealing washer and it works just fine.
Here is a link, pay attention to his 1/4 inch in a penney.
http://www.mesaperformance.com/faqs/idle.html
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
Old 05-04-2004, 08:29 AM   #3 (permalink)
Photos: 0
Smile
Thanks for the reply.
I read your instructions...GREAT! I'm not sure that it's the temperatur though. I probably ought to give you some more info.
Car has been parked for 3 years, so heaven knows what else is going to cause problems. Battery was completely dead - probably for more than 1 year, so I would suspect that any stored info is gone.
The idle issue that is arising appears to be exactly the symptom you described as an OPEN SYSTEM. Idles fast and fine when cold, but as it warms up, it begins a regular cyclic "bounce" between about 12-13 hundred and drops to about 600 or so for a sec then back up.
If I turn the screw on the ICV itself all the way in, the cycle becomes slower, if I open it all the way up, it cycles faster.
During normal driving, the engine appears to work fine (although a bit of a stutter at WOT on acceleration. Most likely, that problem is electrical (plugs, wires, etc.) I haven't bothered to track that down yet because other the the idle fluctuation, the engine runs STRONG. Was rebuilt about 40-50K ago, so I'm going to leave that alone for now I think - it's a minor stutter, not a serious drop in HP.
I'm thinking that the cycling is just too "regular" to be a vacuum leak, and I've blown about 1/2 a can of carb cleaner trying to find one. The initial problem (high idle) was probably due to the tons of carbon in the ICV. I did clean it. Now if I shake it, I get a rattle (like a ball bearing in a can of paint) when I shake it back and forth. Sounds to me like the piston is probably freed up and now working again.
I have changed out the DISGUSTING air cleaner. It had a very weird pattern of dirt on it too. Can't figure out how it happened, but there was a rectangle in the middle of the filter that was entirely black (almost looked like an oil stain). Anyway, breathes a lot better now too. I wonder if the dirty air cleaner was fooling the system......Hmmmm.
Would a dirty MAF sensor cause this? haven't cleaned that yet...
Sorry about the length, but I thought I'd explain as best I could.
Thanks,
Douglas
Old 05-06-2004, 04:00 PM   #4 (permalink)
Photos: 0
Ok, so I'm getting ready to do the penny trick, and just for giggles, I popped my dipstick out to see if the loss of vacuum caused a difference. When I pulled it out, the rpms dropped to about 700 or so and steadied out. What the heck.
By pulling the dip stick, I think I'm introducing a vacuum leak, which should cause a hunting idle. It's working just the opposite.
Any suggestions now????
vB code is On
Erratic Idle / Misfire / Cutting out makdolby 3-Series (E36) 10 12-22-2008 06:25 PM
Idle Problems '95 325is Burnettm 3-Series (E36) 3 04-26-2005 01:41 PM
89 325i Rough Warm Idle And Other Odd Problem mattpark 3-Series (E21, E30) 8 03-19-2005 11:46 PM
1700+ Cold, Warm, All Time Idle MeisterTy 3-Series (E21, E30) 2 12-23-2004 09:40 AM
Warmed up idle puzzle. nightsurfride 3-Series (E21, E30) 2 02-03-2004 09:04 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
