I found a cord underneath the passenger seat. It looks like a cord that you would plug a computer into. (For all you nerds out there, it's a male 9-pin serial plug, kinda like what the end of an old mouse back in the DOS days looked like.)
What is it for? Is it in someway connectable to my laptop so that I may enhance and view performance? I must know all.
where does the wire run? Is it shoddily ran under the carpet or is it professionally done? Ive never heard of a serial cord type plug... unless its for a fuel manegment system, which almost no one does to bmws in general.
__________________ <span style='font-family:Geneva'><span style='font-size:14pt;line-height:100%'><span style='color:red'>Fox</span></span> <span style='color:gray'>the Pirate</span>
Diplomacy is saying "nice doggy" until you find a rock.</span>
If it's original with the car, I doubt it will be compatible with a pc, maybe a service connection for the engine computer which I think is near the glove box
Will I have your attention, is there anyway to replace burnt-out LEDs in the oil/service gauge on the dash below the tach and speedo? Two of five green ones have gone out. I don't know if yellow and red work.
I agree with Aether about it being someone else's project.
But I don't agree about the LEDs. The appear to stick a little out from the board that they're soldered to, but I expect they'd be hard to remove, and also hard to find an exact replacement for.
__________________ <img src='http://bmwforums.penguinstudios.com/BimmerKris/salesig%20copy.jpg' border='0' alt='user posted image' />
<a href='http://www.acantha.ca' target='_blank'>www.acantha.ca</a> 100% thrash your face off metal
Sorry for the short description earlier (sopposed to be working)
Well yes the connector is for the amp and that goes to your portable phone. I still had the actual base on mine on my center counsel. Well I know its safe to pull out or just get some clippers and snip away.
Hope this helps... Good luck.
The LEDs are easy to replace, you first have to determine the pysical size of the LED, they come in two standard sizes. determine the colour and head off to the local electronics store and pick them up. Stay away form Hi intensity LEDs as these will have an negative effect on your ability to see at night if they shine in your face from the dash.
You should have a ohm meter handy to determine which side of the board you are mounting these into is ground. An LED is polarity sensitive and will not work if inserted backwards. Once that is found out , most LEDs have one leg longer than the other and that one indicates the + side (a trick is to use a marker to put a dot on the edge of the LED on the positive side as you will probably have to clip the leads to fit) Unsolder the old LED resolder the new one in. Some form of heat sink should be clipped onto the leg that you are soldering to prevent damage to the LED due to heat. Good Luck.
