After replacing the starter and still not getting anything to turn over I broke down and took the car down to my mechanic. After several hours of tests he finally tracked down the problem to a loose cable that connects the engine to the frame. The connection was not providing enough voltage to the starter. He tightened the connection and everything was back to normal. I guess it was a good excuse to paint the manifold at least and I only spent $25 on ebay for a used starter plus $75 for the mechanic's help, now I'm going to put it all back together.
The thermostat housing and hose coupling were caked with dark orange cosmoline. I couldn't just put a nicely painted intake manifold next to filthy parts so I took them off and spent an hour cleaning them with a wire brush and engine degreaser. I picked up new gaskets and a new thermostat for $20 and I realized the coolant temp sensor for the ECU was very old so I picked up a new one for $15 and refinished the other gauge temp sensor with a wire brush. Next up I'm gonna paint the valve cover with black wrinkle high temp paint and I have new carpet going in.
Jedz123.
Great write up. I have a starter I need to replace on a 1990 325i E30. I am not able to lower the transmission at all. Can the starter be removed without lowering the transmission? I saw some pictures of people having top part of the engine taken off. I am going to be starting Thursday and hope to have it out. I have all day to work on it.
Thank you,
Claps1775
So I can get to both bolts from the top and get it out? Thing is getting to the bolt on the bottom so it will not turn is challenging.
Thank you,
Claps1775
once the manifold is off there you can get all the starter bolts off really easy. After you've taken it off once it doesn't seem like such a big deal. After the first time I ended up having to remove it again because a coolant hose burst under there. If you have trouble with the manifold bolt studs I would replace them with new ones from napa they are really cheap.
When you took the intake off, did you reuse the gasket or buy a new one? I am not trying to buy extra parts.that are not needed. Right now I have all off but the intake and heater core lines. A 15 mm fits on the starter nut. The bolt looks a torques head but not sure of the size. I have the bmw on one Jack stand on the drivers side. Looks like an easier way to get the bottom bolt off. Doing this in a unheated garage with a space heater. Also no electricity but my drop cord lol.
Thank you,
Claps1775
I did all mine out in the open air. I would replace the gaskets if it's the first time you've pulled it off, they will probably tear when you pull them off anyway. The intake manifold gaskets shouldn't cost more than $10. I usually check ebay or google e30 intake manifold gasket and click on the shopping tab to check prices. I also check pelican parts but they should also show up automatically under the google shopping search. I also ended up getting a new throttle body gasket and new bolts and bolt studs. While you have the manifold off it's a good time to spray it with heat resistant spray paint.
How did you get the bolt from spinning? I just put my long extension on and hooked it to my 3/8 cordless. Turned it slow but the bolt spin with the nut put heat and sprayed pb blaster and tried again. Still spun and even when I gave it all power. I really thank you for helping me. Not sure if I got a pry bar and wedge it to stop the bolt from spinning or if it would stop. The intake does not look fun to take off by the way lol.
Thank you,
Claps1775
Sounds like it's stuck on there. I had a real problem with those old bolts too the first time, the bolt stud threads were rusty and damaged and the bolts were hard to get off. Try taking the bolt stud out of there with the nut on it. If you can't get the stud out of there maybe you could use a reciprocating saw to cut through it if you can get enough room in the gap between the head and the manifold for it.
How would I be able to get the stud out? I was not aware it was a stud. I thought if I could get vice grips on the tip of the bolt/nut side and hold it from moving to get it off. Just put a new bolt/nut on. I will shoot back Saturday on my work.
Thank you,
Claps1775
I am making nice progress. I am stuck on removing the intake. What is the best way on removing this tube? I think its to blow by for the crank case ventilation.
Thank you,
Claps1775
