Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 10-05-2005, 02:08 AM   #1 (permalink)
Photos: 0
träumer is an unknown quantity at this point
how to detect eta engine hexagon head bolts
my car is a 325e and want to know if the engine has torx or hex head bolts.i was told to open the engine oil filler cap and illuminate with a light and check visually the head of the bolts. i have attempted to tell the difference to no avail is there anyother method to detect hex head bolts. i want to change them as soon as possible if i have them. thanks
träumer is offline   Reply With Quote
Old 10-05-2005, 11:14 AM   #2 (permalink)
Photos: 0
You may have to remove the rocker cover to she the heads of the bolts I have a drawing showing the difference but since the site has changed I can't work out how to attact it email me through the site if you need it
Old 10-05-2005, 12:26 PM   #3 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Photos: 5
Take the oil fillter cap off and look inside. If you see a bolt with a head like this, you have the hex head bolt. If the head of the bolts look like this you have the torx ones.
My M50 Powered E30 Page
Old 10-05-2005, 03:08 PM   #4 (permalink)
Idle Member
luckycat's Avatar
Photos: 0
luckycat is an unknown quantity at this point
Red face head bolt nonsense!
Hi,
Why are you concerned about the head bolts? The current mania about changing the 17mm factory bolts for hex-head is in my opinion, patent nonsense. First of all unless you have a need to repair a valve or gain access to the block for some reason, you should never remove head bolts, even one at a time, as you run the risk of unseating the head gasket. I just did a valve job on my 325IC at 200,000 miles, and following the advice of my machine shop, (thirty years of experience with BMW engines) I measured the original 17mm head bolts for length, making sure none had stretched, (they had not ) cleaned and oiled them, and put them right back in. The car runs fine! I also find the tightening sequence for hex bolts confusing; The torque instilled by turning them an "extra 90 degrees is vague. I'd rather use a conventional bolt with a reliable torque wrench. Instead of forking over $70.00 to the hex bolt people, give it to your favorite charity instead. My opinion. Good luck!
luckycat is offline   Reply With Quote
Old 10-05-2005, 08:04 PM   #5 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Photos: 5
There have been issues in the past of the hex head bolts having the head of the bolt come off due to a design flaw. There is a TSB from BMW stating this issue and advising using the updated torx head bolts. The later production M20's came with the updated torx head bolts. I work at an independant BMW shop and we replace the hex head bolts for the torx head ones all the time just doing one bolt at a time with no problems. When I got my E30 the first thing I checked when I went to look at it was the head bolts. Personaly I'd rather spend $40 on a full set of head bolts than $250 to get my head rebuilt, but thats just me. Turning the bolt an extra 90* is not vauge, its called a torque to yeald spec. You will find this a lot in engine building and it actually produces and more accurate tightening of the part. I hope you didn't use oil to lube your bolts, if you did your torque is going to be off. Its best to install bolts dry or at most with a very light coating of machine oil.
vB code is On
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 11:50 PM
Bizarre Head Bolts 85-325e 3-Series (E21, E30) 7 02-17-2005 05:12 PM
Loud Engine Noise And Head Gasket Problem dshrewd1 3-Series (E36) 0 11-12-2004 05:25 PM
BMW P83 Engine triggrhaapi Bimmer Talk/Motorsports Talk 0 07-21-2003 03:03 PM
Engine noise difference? 325 v. 328 nosuchsol 3-Series (E36) 13 05-30-2003 10:03 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
