High Speed Stability - BMW Forum - BimmerWerkz.com
Old 09-26-2004, 12:03 PM   #1 (permalink)
ye12 is an unknown quantity at this point
I recently purchased a 1989 325i and installed eibachs, konis, RH 17x7.5 and Yokohama 215x40x17 AVS E100's. When I am driving around 140 KPH, especially around corners with slight dips in the road, the 325 feels a bit twitchy. I've had two alignments done since the upgrade and the car has 140,000 Km on it. I had all front and rear suspension parts that were worn replaced.
Do all e30's feel this way a high speeds. It feels like I have to really concentrate on how the car is handling at this speed and if I don't, I may lose control. My Acura 3.2TL did not feel this way at even higher speeds.
ye12 is offline   Reply With Quote
Old 09-26-2004, 12:10 PM   #2 (permalink)
Aether's Avatar
Car: 1992 Jetta GLI
Aether is an unknown quantity at this point
Send a message via AIM to Aether Send a message via MSN to Aether
Your TL is front-heavy and probably wider than an E30. Front-wheel-drive cars aren't necessarily better handlers than RWD, but they are more stable in extreme situations. It's not at all hard to kill yourself in either, of course. My 1987 325 feels pretty loose even through minor turns at 90 and up, on 195/55/14s. I'd say it's normal. You could get some strut braces or something if you're going to be playing around at those speeds often.
You really should be concentrating on the car's handling at that speed regardless.
Four Five Six - It's on.
Aether is offline   Reply With Quote
Old 09-26-2004, 12:30 PM   #3 (permalink)
[snapback]199324[/snapback]
Thanks Aether, Its good to get this kind of feedback. I do have a front strutbar ordered from Ireland Engineering. I't been over 3 weeks since they said it was shipped and I'm still waiting for it.
Old 09-26-2004, 01:19 PM   #4 (permalink)
i dont know what could be causing the unstability at those speeds. ive had my car up to 115mph (at the track) turning on a downhill banked turn on the absolute limit and the car felt amazingly stable. even on the highway with random dips or bumps the car feels very stable at 100mph+ speeds. all i have done that would really help stability is koni sa dampers and a sparco strut brace.
did you replace the control arms, control arm bushings, and tie rods? if not, look into e36 tie rods and e30 m3 control arm bushings for better stability. the strut brace should help alot as well.
Old 09-26-2004, 10:39 PM   #5 (permalink)
[snapback]199361[/snapback]
I have the m3 control arm bushings installed. It helped to tighten up the front end. The rest of the front end was tight, so I never changed it. I was looking at changing the rack to an M3 rack that uses e36 tie rods. That might be my next step....... thanks!
Old 09-26-2004, 10:47 PM   #6 (permalink)
Official Bimmerwerkz Biscuit Distributer
spiff325is's Avatar
Car: 00 M Coupe
spiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud of
Send a message via AIM to spiff325is
You should always be concentrating. It may depend, if you are just coasting, or have the brakes on, your rear end may be slowly letting up, thus your rear wheels are sorta bobbling because there isnt much weight in the back.
Id suggest using gas through the turn. Or your rear shock mounts may be worn so you hear some squeaking. But along the lines of twiching, i cant say id know what the problem is unless i drove your car. or if you gave a more detailed description of the feeling.
I hate: people who haven't died yet that I hate.
L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc.
2000 BMW M Coupe - Dakar-II - S52
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
spiff325is is offline   Reply With Quote
Old 09-27-2004, 12:20 AM   #7 (permalink)
[snapback]199693[/snapback]
When I went around the corner at 140 KPH, I was coasting and when I hit a small dip in the road while cornering, the rear felt like it may do something strange, like oversteer. Mayby I'm not used to the way the e30 handles. Both my front and rear suspension are tight. I have new eibachs and koni adjustable. The koni's are set at 1 3/4 turn on the rear (max 2 turns) and the fronts are set at 1 1/2 turns (max 2 turns). Maybe I need stiffer sway bars?????
Old 09-27-2004, 12:46 AM   #8 (permalink)
Fox
Moderator
Send a message via ICQ to Fox Send a message via AIM to Fox Send a message via MSN to Fox
mines smooth up to 140 where it tops out.
Fox is offline   Reply With Quote
Old 09-27-2004, 02:05 PM   #9 (permalink)
bavarianmotorweapon is an unknown quantity at this point
my 318i, with a pretty close to stock suspension, handles fine up through 90mph (145kph), it is totally pinned down. Around 120-125ish, it starts to lift up and get a bit drifty, but can be controlled through 135ish where it runs out of steam. Lowering the car is supposed to help this. I used to have those AVS100 tires, they aren't the greatest in my experience. A TL has a softer suspension, and tends to feel more relaxed. I have an acura RL, which feels very calm at 120mph speeds, but you can feel it doesn't have much grip. The E30 is just very tight, anything happening with it, you feel.
A BMW is a beautiful car from almost any angle, but none so much as the one from behind the wheel.
bavarianmotorweapon is offline   Reply With Quote
Old 09-28-2004, 05:22 PM   #10 (permalink)
Thanks guys for all your responses. I'm getting to know more of how the E30 is designed to handle and it looks like the E30 is designed to feel everything that is happening. I'm really enjoying driving it.
Old 09-28-2004, 06:31 PM   #11 (permalink)
shield is an unknown quantity at this point
My vehicle is stock, but the entire steering (rack pinion kit, links, etc), struts, shocks, and tires are all brand new. But I experience the same thing as you described.
I think it feels like this since it's rear wheel drive.
I've driven a couple of others as well and they feel the same.
My Civic feels more stable since it's front wheel drive.
However, my highspeed turns are pretty tight and I have no issues in winding roads at high speeds.
Overall, my Bimmer handles pretty well comparetively...(considering I do ~200 K/hr in a police car on the highway on a daily basis)
shield is offline   Reply With Quote
Old 09-28-2004, 08:03 PM   #12 (permalink)
Ian-318i is an unknown quantity at this point
[snapback]200028[/snapback]
....How did you get your E30 318i to 181 hp?
<img src='http://sigs.pandorafarmsshar-pei.com/sigfiles/Bush.gif' border='0' alt='user posted image' />
Ian-318i is offline   Reply With Quote
Old 09-28-2004, 08:38 PM   #13 (permalink)
It should not be twitchy at any speed. My E30 is stable al the way to top end
Old 09-28-2004, 10:30 PM   #14 (permalink)
[snapback]200954[/snapback]
I'm from Vancouver as well (Coquitlam) and it's good to hear from an E30 owner in the same area. I thought of test driving other E30's as well to see how they handle, but I see you have already done that. Are you with the RCMP or Vanc City Police?
Old 10-01-2004, 06:33 PM   #15 (permalink)
[/quote]
[snapback]201149[/snapback]
[/quote]
Cool,
I'm a city cop.
Engine Stutter at high speed...HELP !!! 323iguy 3-Series (E21, E30) 6 10-13-2005 07:28 PM
Strange Flapping Sound At High Speed ben_t 5-Series (E12,E28, E34, E39, E60) 1 03-29-2005 09:16 PM
....high Speed 318 Numark318i Driving Tales 23 11-07-2004 11:48 PM
