Hesitation Problems - BMW Forum - BimmerWerkz.com
Old 07-31-2005, 10:46 AM   #1 (permalink)
race01 is an unknown quantity at this point
1987 325e. Hesitates when accellerating. Changed plugs, wires, coil, flywheel transmittors. Is this an electrical problem, or an injector issue? Otherwise car runs fine.
race01 is offline   Reply With Quote
Old 07-31-2005, 11:15 AM   #2 (permalink)
Justin318is is an unknown quantity at this point
hey i have the exact same prblem but i have a 318is and ever since i bought it it have been slowly going down hill it hesatates off the line
Justin318is is offline   Reply With Quote
Old 08-01-2005, 06:53 AM   #3 (permalink)
[snapback]366374[/snapback]
Thanks
Old 08-01-2005, 08:31 AM   #4 (permalink)
77th Gear Member
325eXTATIC's Avatar
325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light
Send a message via ICQ to 325eXTATIC Send a message via AIM to 325eXTATIC Send a message via MSN to 325eXTATIC Send a message via Yahoo to 325eXTATIC
have you checked your Oxygen Sensor?
If it has gone bad, it may send mixed signals, or no signal at all to the DME. It caused hesitation and erratic acceleration in my 86 325e. Once I changed it (kind of a pain in the A$$, because the heat of the exhaust nearly welded the old sensor in place, I recommend renting an O2 sensor removal tool from an auto parts store!)
Just my first guess, hope it helps!
Josh W.
'86 325e w/Dinan ECU
Not currently on the Bimmer kick. Drivin' a 2003 Silver Civic at the moment, but I am STILL the Founding Member of the "325eXTATIC You're my hero" club.
Originally Posted by <b>superdeadman</b><br>Josh W. IS my hero!
325eXTATIC is offline   Reply With Quote
Old 08-01-2005, 09:45 PM   #5 (permalink)
gsrboy171 is an unknown quantity at this point
samething with my car
the code gave off o2 sensior
how much does it cost?
<span style='font-size:14pt;line-height:100%'>NYC WHAT'S UP!!!</span>
gsrboy171 is offline   Reply With Quote
Old 08-02-2005, 06:40 AM   #6 (permalink)
Josh W.
[snapback]366588[/snapback]
Thanks. I don't think that I replaced that yet. I'll give it a try and let you know.
Old 08-02-2005, 06:41 AM   #7 (permalink)
[snapback]366732[/snapback]
Thanks. Your car looks sweet. What kind/size rims are they?
Old 08-02-2005, 08:26 AM   #8 (permalink)
77th Gear Member
325eXTATIC's Avatar
Oxygen Sensor SHOULD be around $120
http://www.pelicanparts.com/BMW/catalog/sh...s_pg2.htm#item5
Oh, and I would recommend getting this taken care of very quickly because when the O2 sensor goes bad, the engine starts spitting out things like unburned fuel, and other such nastyness which will VERY QUICKLY ruin your Calalytic Converter. If that is the case, I recommend going to magnaflow and getting a universal cat and having a muffler shop replace it for you (the will need to fabricate a 2 into 1 and 1 into 2 adaptor to connect to an aftermarket cat) if you have to deal with emissions wherever you are. http://www.car-sound.com/catalog/universal/940.aspx
Hope This Helps!
Josh W.
Old 08-02-2005, 11:28 AM   #9 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
Hope This Helps!
Josh W.
[snapback]366817[/snapback]
buy a universal metric 4 wire o2 sensor. the bosch ones cost about $80 @ autozone
Old 08-02-2005, 06:40 PM   #10 (permalink)
Originally posted by race01+Aug 2 2005, 05:41 AM--><div class='quotetop'>QUOTE(race01 @ Aug 2 2005, 05:41 AM)</div><div class='quotemain'><!--QuoteBegin-gsrboy171@Aug 1 2005, 09:45 PM
[snapback]366804[/snapback]
[/b][/quote]
they are 15's on 215's old school MOMO rims
Old 08-02-2005, 06:42 PM   #11 (permalink)
Originally posted by nukeduster+Aug 2 2005, 10:28 AM--><div class='quotetop'>QUOTE(nukeduster @ Aug 2 2005, 10:28 AM)</div><div class='quotemain'><!--QuoteBegin-325eXTATIC@Aug 2 2005, 05:26 AM
Oh, and I would recommend getting this taken care of very quickly because when the O2 sensor goes bad, the engine starts spitting out things like unburned fuel, and other such nastyness which will VERY QUICKLY ruin your Calalytic Converter.* If that is the case, I recommend going to magnaflow and getting a universal cat and having a muffler shop replace it for you (the will need to fabricate a 2 into 1 and 1 into 2 adaptor to connect to an aftermarket cat) if you have to deal with emissions wherever you are. http://www.car-sound.com/catalog/universal/940.aspx
Hope This Helps!
Josh W.
[snapback]366836[/snapback]
[/b][/quote]
will the threading nut will be the same??
and the 4 wire type conector will it be the same??
Old 08-03-2005, 01:40 PM   #12 (permalink)
Celsdogg's Avatar
Car: BMW E30, Subaru BE, Cannondale M400
Celsdogg is an unknown quantity at this point
Send a message via ICQ to Celsdogg Send a message via AIM to Celsdogg
also try pouring some techron in ure gas tank, sometimes that helps clean out injectors, etc. in the absence of a real cleaning. . .
Celsdogg is offline   Reply With Quote
Old 08-04-2005, 04:22 PM   #13 (permalink)
OK. Changed O2 Sensor (Bosch $ 120.00). Also changed fuel filter. I've put fuel injection cleaner into tank as well. Still the same deal. Throttle Positioning Sensor? Seems to do it more when first driving it. Cold Start Sensor?
Old 08-05-2005, 09:41 AM   #14 (permalink)
77th Gear Member
325eXTATIC's Avatar
[snapback]367400[/snapback]
Look up "Hot Soak" on the forum and follow that procedure. Sounds like the injectors are clogged or the valves are gummed up. A good Hot Soak of the engine should open it up a bit (possibly, if the injectors are TOO bad, it is time to replace them though http://www.fiveomotorsport.com/Injector_SetsBMW.asp)
I know mattpark and Bmw1990 have both replaced their injectors with Ford 19# injectors with some level of success, check with them!
Hope this helps!
Josh W
Old 09-07-2008, 09:36 PM   #15 (permalink)
jackx84's Avatar
Car: 1996 328i conv
jackx84 is on a distinguished road
Exclamation 1996 328 engine surging
Hey guys,I've got a 96 328 conv. Yesterday, It started surging on the highway.Not real bad, but to the point you could feel it and see the manifold press gauge (fuel econ) move irratically-about 2 mpg. Idles fine and smooth. any Ideas?(vac leak,fuel press, misfire?) (No emission codes or ck light)Thanks, Jack
jackx84 is offline   Reply With Quote
Climate Control Problems black318 3-Series (E36) 0 02-24-2005 02:00 AM
94 325is Problems sre2114 3-Series (E36) 23 10-21-2004 04:27 PM
