| Take a look underneath and see if you have enough clearance between the pan and cross member/steering rack, just remember if the pan is say 75mm deep you will need say 50mm from the bottom of the pan to what ever is in the way to get it out as your con rods do go down in to the oil pan.
__________________ VELVET BLUE UK INDIVIDUAL , IM THE LAST  UNITED WE STAND DIVIDED WE FALL
