hi was wondering if anyone could help?
I have an 87 e30 325i sport when you turn the ignation on the car turns over but wont start it seems to be turning over very fast but the cylinder test was fine. the car will start on a bump and runs fine.
here,s a few things i,ve tried.
new plugs, leads, distributer cap rotor arm and battery.
when you check the coil with the ignition on there is 12.17 volts and when winding over its 10.47 volts and same with the main ht lead but when you check the plug leads when trying to fire the engine theres no spark or voltage. i,ve even change all the relays and check all fuse,s.
really need some help as my heads has been wrecked now for a full week.
cheers
