OK, I'm going to look silly but I've just bought a 1987 BMW E30 325i and the engine is nothing like my last car, I have 2 very basic questions.
The control panel is coming up that cooland and engine oil both need checking.
1. The coolant light came up yesterday, I added water (to the bit marked "E" on the picture of the engine) and the light is still coming up, does anyone have any ideas? The engne is not overheating, it is going to half way which is normal as far as I'm aware.
2. It says it needs engine oil, which bit do I put it in, I am assuming the oil goes in the bit marked A on the picture attached, (G being the dipstick).
I know this is seriously basic stuff, but thanks a lot for any help, is there a book or somewhere I can get the user manual from, I have only just got the car and can't even do basics on it as it's so different from my old car.
Bentley service manual Page 2-11 column 1 section 4.
The power steering fluid is Dexron or Dexron II ATF. The system is permantly filled and does not have a drain. Routinely adding ATF is not required unless the system is leaking
It also says on the cap.
Why would I tell you the wrong info? Unless you want to purchase a rack, use the right fluid or you will be buying a new rack like I have to due to previous owner.
not its it uses atf fluid same on newer bmws as well, labeled on them though.
mtecnik knows his shin-izzle. isn't "f" the brake fluid resivoir cuase hes driving on the other side... (maybe not its a small pic)
wait, the power steeriing uses atf, as in Automatic transmission fluid? WHAT THE HECK!!!....i have a friend, who might need to drain his ps fluid reservoire, how might he go about that....i know, i mean, he knows, it doesn't drain, but still, any bright suggestions?...
If the lights by the rear view mirror are still on hold down the "check" button and they should turn off if your levals are back to normal.
ATF= Automatic Transmission Fluid.
M-technik-3 laid it all out for you.
__________________ Member: "Ran from a cop and got away" Club
Member: "Old Guys Rule" Club
Originally posted by Bimmin'88@Oct 10 2004, 03:15 PM hold down the "check" button and they should turn off if your levals are back to normal.
Thanks man, that's great, I've just filled the coolant right up to the line, if it's still not working I'll take it to the mecanic as there may be a leak.
...and I've just worked out how to get rid of the annoying service light on the dashboard at Draper Tools who do a bmw reset key...
[snapback]208634[/snapback]
Ok if you coolant light is coming on there is a float in the expansion tank. Remove it clean it and the electrical contact and put it back in place try that before taking to mechanic. It should not take you more than 10 minutes.
