Help with my 89 BMW. - BMW Forum - BimmerWerkz.com
Old 05-22-2004, 09:35 PM   #1 (permalink)
Car: Opening soon:
I just got my first 1989 BMW 325i and it has issues with the VDO cluster. First off the tach and econometer don't work, I checked the fuses, and found 30 amps where only 10 amps should be. “Things that make you go hmmmm.” To save me a lot of unnecessary drama of trying to figure this out, maybe some one else had this problem I do. I'm missing something or am I right in thinking the tach and mpg gage are shot, or is it deeper.
Also the service light and the yellow and red lights were on. I tried to reset the service light and it didn't work, I then replaced the 2 short 3V batteries on the inspection light board. $17.00 and 1 hour later the yellow and red leds are out but inspection light stays on and will not go out by the normal clearing method. Did I miss something?
I'm thinking that I may very well have to get another instrument cluster because the odometer gears are busted. If the cost to fix it is unreasonable, does anyone have one that works for a reasonable price?
Old 05-24-2004, 12:57 AM   #2 (permalink)
heifetz17's Avatar
heifetz17 is an unknown quantity at this point
Send a message via MSN to heifetz17
Maybe there's a broken connection where the instrument plugs in. Or a sensor or something may be out.
heifetz17 is offline   Reply With Quote
Old 05-26-2004, 06:22 PM   #3 (permalink)
DANM is an unknown quantity at this point
change the batteries in the instrument cluster,you can pickup rechargable at radio shack with the solder tabs, i mounted mine remotely so i would not have to go back into the instrument cluster to change them later,its not a bad job mabey an hour or so good luck
DANM is offline   Reply With Quote
Old 05-29-2004, 12:49 AM   #4 (permalink)
Car: Opening soon:
Uh, I did that.... I found the problem. Thanks anyway.
