Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 10-06-2005, 02:33 AM   #1 (permalink)
Photos: 0
träumer is an unknown quantity at this point
help me find the right spark plug for a 325e
i would like to give the car i just bought a refreshment in all areas.spark plug wise what should i get?4 electrode bosch platinum, or i have heard bosch silver is the best for the e30.what is the oem sparkplug for the 87 325e?should i look for sparkplugs at the dealer or local autozone.?
or should i just pull out the spark plugs i have right now and put ones that are similar to what i have?
again i will be doing the coolant flush when i change the water pump. which coolant is better blue or green, which brand of coolant do u guys recommend
and what brake fluid should i use dot 3 or dot4 or should i use bmw brake fluid is it worth it?
sorry for the common questions just a newbie wanting to get it right on his first bimmer
träumer is offline   Reply With Quote
Old 10-06-2005, 11:57 AM   #2 (permalink)
77th Gear Member
325eXTATIC's Avatar
Photos: 0
325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light
Send a message via ICQ to 325eXTATIC Send a message via AIM to 325eXTATIC Send a message via MSN to 325eXTATIC Send a message via Yahoo to 325eXTATIC
I have an 86 eta and I put platinum +4's in it and it ran worse than with the stock old plugs. Get STOCK Bosch plugs. I don't remember the part number, but just your standard plugs and gap them right. BMW knew what they were doing and they didn't skimp on the plugs!
As for coolant, you will hear many arguments about Blue vs. Green coolant. Many die hards will tell you ONLY USE BLUE, it is what BMW uses, so YOU should use it. I personally use Prestone (I THINK...). It does the job, and as long as you use distilled water to mix it with, I don't think you will see too many issues.
Hope this helps!
Josh W.
Not currently on the Bimmer kick. Drivin' a 2003 Silver Civic at the moment, but I am STILL the Founding Member of the "325eXTATIC You're my hero" club.
Originally Posted by <b>superdeadman</b><br>Josh W. IS my hero!
325eXTATIC is offline   Reply With Quote
Old 10-06-2005, 12:13 PM   #3 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Photos: 5
BOSCH spark plug WR9LS is what you should use. The plat. plugs are a waste of money and dont work well with the older ignition systems. The older ignition systems wont get the plat. hot enough causing them foul out sooner than a normal copper or silver plug.
Blue or green coolant doesn't matter. The blue BMW coolant is a little more refined and lasts longer but the regular green coolant works fine. We use Peak brand coolant at the shop I work at in the older BMW's and have seen no problems and I run it in my E30 with no problems.
My M50 Powered E30 Page
Old 10-10-2005, 06:35 PM   #4 (permalink)
Photos: 0
miami325e is on a distinguished road
i got wr9ls and i think this is the best.
miami325e is offline   Reply With Quote
Old 10-12-2005, 04:39 PM   #5 (permalink)
Photos: 0
i got the plugs wr9ls and installed them and they worked fine. the idle smoother the engine is quieter. less hesistation
vB code is On
spark plug wire check and ignition maitenance träumer 3-Series (E21, E30) 1 11-06-2005 02:19 PM
Whats good spark plug for 89 325i Slow325i 3-Series (E21, E30) 4 10-31-2005 06:44 PM
spark plug drenched in oil Beemerguru 3-Series (E36) 2 10-06-2005 11:06 PM
New Spark Plug Wires For All You E30er's(Bavauto Plug Wires) Bmw1990 Product Reviews 1 09-08-2005 04:31 AM
Does This Spark Plug Look Normal ? pcy 3-Series (E36) 2 03-19-2005 05:40 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
