Help Me - BMW Forum - BimmerWerkz.com
Old 10-27-2005, 01:04 AM   #1 (permalink)
badong1050 is an unknown quantity at this point
Help Me
Just replaced water pump, timing belt, and thermostat in my 1987 325is. yet after reassembling the engine it still heats up..fast. there is no visable coolent leak. the car randomly will start to heat up and i have to shut it off before it overheats. Ive flushed the coolent, re-filled. multiple times. yet i start it up, it starts to warm up, them all of a sudden it heats up fast. any suggestions? Ideas?
-thanks
badong1050 is offline   Reply With Quote
Old 10-27-2005, 01:17 AM   #2 (permalink)
Charleston Chu is on a distinguished road
Send a message via MSN to Charleston Chu
Check the fuse for your aux fan. Mine blows on really hot days when the fan and other electrical connections on that circuit can't keep up. Try that... otherwise else... lower temp thermostat (you can get one 12 degrees Cecius colder then stock... typical for E30's to over heat) or new radiator... not good... hope that helps.
Preston
Charleston Chu is offline   Reply With Quote
Old 10-27-2005, 10:59 AM   #3 (permalink)
DJProfessor's Avatar
DJProfessor is an unknown quantity at this point
big ole' air pocket in the system........you need to turn your heat to full blast and take off your coolant cap.........you need to bleed all the air out of your system.
sexually assault a member of the VW community? if you belong to dubdojo or swov.org they will gladly circle their wagons and support you.
DJProfessor is offline   Reply With Quote
Old 10-27-2005, 05:34 PM   #4 (permalink)
german-speed-demon's Avatar
Agreed. It sounds as though you have an air pocket in the system.
R.I.P fast 6
Old 10-31-2005, 06:14 PM   #5 (permalink)
thanks guys. it was an air pocket.fixed and running now.
thanks for the help
