to tell me is fuse #23 a 7.5 amp on a 1988 e30 325i.....my psngr pkng lite and rear psngr lite and instrument cluster are not working...what else is on this circuit....PLEASE PLEASE HELP ME.....thanks
I own a 1994 318is car was starting but I noticed not all dash systen lights were working i noticed ,wires unplugged from underneath. Iam a shop owner in Hesperia CA.
Of body repair. well I plugged A round speaker type looking thing that when I plugged wires properly it beeped and know vehicle does not want to turn on . All instrument panels are working properly know ,but it wont start . Can you please help me .
i've disconnected the battery overnite...it worked....then i used the headlite switch and: #23 blew again....i need a little help from anyone....thanks
Tracing time. You might have a short on one of the wires. Go thru the elimination process adn definetly use the diagram. It saved my life alot in the past.
How do I spell relief?!?!?! NO MORE DAMN SNOW!!!!!!
Yep, trace the wires from the headlight switch out to ALL the lights that are on 23 you know it is after the switch because the fuse doesn't blow till the swich is pulled
1992 318i Coupe parts car
im having trouble removing lite switch from dash...any suggestions.....when tracing wire for short am i using a contiuity tester or ohm meter...any help will do
finally removed the lite switch....cleaned it up but short continues.....is there a way to test the lite switch...it works so could it be causing da short....thks
